69Views6Replies
Author Options:
which rating resistor to put before a 4v, 3.3ohms 1.2a stepper motor to prevent any damage to the motor? Answered
Re-design
Re-design
11 years ago
If you use 4 volts then you don't need anything.
What is your power supply voltage?
crispycat
crispycat
Answer 11 years ago
the voltage will be 12v
im using the easy cnc driver circuit
https://www.instructables.com/id/Easy-to-build-CNC-Mill-Stepper-Motor-and-Driver-ci/
i want to replace the lightbulb with a resistor as i cant seem to get the bulb rating right and not too keen on being blinded and burning myself on hot bulbs :)
unfortunately im new to electronics .. so good at following guides but clueless at trying to alter things myself
steveastrouk
steveastrouk
Answer 11 years ago
No, you can burn yourself on hot resistors instead..its inevitable. You need a (12-4)/1.2 Ohm resistor on each winding.
Re-design
Re-design
Answer 11 years ago
THen you need to get a voltage regulator and use that to reduce it down to 4 volts.  Radio shack has a variable regulator that you can just dial in 4 volts with just a few parts.
lemonie
lemonie
11 years ago
What are you powering it from, and do you actually have what you need to control a stepper-motor?
L
steveastrouk
steveastrouk
11 years ago
Well you CAN do it like that, except you don't get decent speed out of it.
Steve
