4467Views12Replies
Author Options:
why does the arduino work with one servo but not two? Answered
well i got an arduino few days ago, just installed the sweep program on it and made it a little bit faster with the sweeping
heres the code:
// Sweep
// by BARRAGAN <http://barraganstudio.com>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop()
for(pos = 0; pos < 180; pos += 10) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(20); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=10) // goes from 180 degrees to 0 degrees
right so, it works with one servo, but as soon as i add a second servo the amber light starts to flash and the servos stop, and carry on strangely... why? is it the code? if it is plz tell me whats wrong...
I pasted the code so you can try it with your arduino, and i dont have to upload a vid :P
Thanks
Noodle93
10 years ago
Are you using a separate power supply for the servo's? If not there's your problem. You begin to overload the power, and it will essential 'crash'.
amando96Noodle93
Answer 10 years ago
ohhh gotta be it, i am just using the 5v pin for both the servos...
Noodle93amando96
Answer 10 years ago
Yep that'll do it. Just get a 4xAA battery pack and use that. Also pick up a 9v battery connector and some batteries :) Nothin beats having arduino without the wires!
amando96Noodle93
Answer 10 years ago
i connected the servos to the 4xAA battery pack... and the 9v battery to the arduino, but the servos go mad and dont do what they are told... so is it suposed to only be the signal wires from the arduino to the servos? or is the red and black wire suposed to be connected to both the arduino AND the battery pack?
Noodle93amando96
Answer 10 years ago
Ok. You need to have the signal pin connected to the arduino. Then connect the servo positive and ground pins in parallel to the battery pack. You then need to tie the grounds of the servo pins and the arduino ( I had this problem when I started). So just get a wire from the ground of the battery pack to the arduino. Hopefully you'll understand this. ;) have fun. P.S It's impossible to say how long it'll last on a 9v battery. But for one, I'm pretty sure arduino doesn't use that much juice, but the 9v battery has a low mAh (milli-ampere hour) rating so yeah. But it'll last long enough probably.
Wesley R TechNoodle93
Answer 3 years ago
Im having the same issue. I am using a 2*AA pack for 2 servos. Only one works. If I try 4*AA they will both go?
amando96Noodle93
Answer 10 years ago
ok so the signal wires and the GND wires are connected to the arduino? hey it worked! i dont understand why though... =/ is the GND partly a signal aswell?
BIGBUGamando96
Answer 10 years ago
Better late than never... Regardless of voltage all voltage supplies must share a common ground.
amando96BIGBUG
Answer 10 years ago
yer i've noticed with some other stuff aswell :)
Noodle93amando96
Answer 10 years ago
No. But simply put. You're outputting voltage from Arduino to the servo via the signal pin, but it's not getting anything back! Remember, you can plug a LED into pin 13 and turn it HIGH but it won't do anything, the other end needs to be plugged into GROUND for electricity to flow! This is the flow of electrons! So we ground the arduino and the servo's so that everything flows. Have fun :)
amando96Noodle93
Answer 10 years ago
yea i know that! lol but like it doesnt make sense :O i'm missing something... hmmm thanks a lot though, wouldnt get there on my own xD
amando96Noodle93
Answer 10 years ago
yea i still have the 4xAA battery pack from the RC car :) and how long does an Arduino usually last with a 9v battery? thanks
