i want to pick up a hotspot down the street with a poormans wifi rig on my balcony/roof (usb receiver in a parabolic dish) , but instead of it running into my laptop i want to pipe it into a wireless router in my apartment. i have both an airport extreme and airport express at my disposal, both of which have usb ports. there also might be an option of using/rigging a usb to ethernet thing to make it less confusing for the router.
The USB fob won't connect directly to your router, as far as I know. Better solution would probably be to hook the routers up back to back, then run the antenna connection from one though a suitable cable up to your roof and to a directional antenna (websearch "cantenna").
Hi! I don´t think it would work, the USB ports on your routers are meant for printers, external drives etc..... the routers can´t process the signal coming from the usb wifi adapter... Maybe there is another way to connect an external (non-usb) antenna to to your routers.
A little clarification is needed... but from what I understand, you want to make a cantanna, then feed that signal into another router, using it to relay wifi to multiple computers. Right?
Or do you simply want internet one one computer using a cantanna?
Either way, keep in mind when free-sourcing wifi, speeds can be quite slow at times, trying to run many computers on one router.
10 years ago
It may. You haven't given anywhere near enough details to provide a better answer than that.
Answer 10 years ago
Note too that you haven't said anything about connecting your WiFi router to the public networks...
Answer 10 years ago
Answer 10 years ago
10 years ago
10 years ago
Answer 10 years ago
Answer 10 years ago
I don't begin to know how you'd go about doing this... Maybe someone else can answer your question.
