61Views12Replies
Author Options:
will i be able to make a poratable electricity generator by wind to recharge a mobile during travels in bus or a train? Answered
5volts 0.55amperes
rugadameghanath
rugadameghanath
10 years ago
hii guys i am back after a large gap i dont know whether u remebered me or not but i now want to start a real beging to get my idea into reality so can u plzz help me do hoping a reply soon from you all my contact +919043625147 rugadameghanath@gmail.com meghanathrugada@yahoo.com
lemonie
lemonie
11 years ago
You know of those portable battery-powered fans? I'd suggest using one of those as a generator - take the batteries out. L
rugadameghanath
rugadameghanath
Answer 11 years ago
which motor best suits the purpose of giving out put 5volts 0.55amp
lemonie
lemonie
Answer 11 years ago
I don't know, but I would think you might get that out of a standard 6V motor (spinning fast enough)?
rugadameghanath
rugadameghanath
Answer 11 years ago
but i think this will burn out even at lesser power input than a mobile phone so it cannot produce a output which suits a mobile phone
lemonie
lemonie
Answer 11 years ago
They're supposed to run at roughly that sort of power, I only suggest it as something that you could easily try (in the first instance) without spending a lot of time / money. L
seandogue
seandogue
11 years ago
yes, but it will present a drag on the vehicle greater than or equal to the power generated by the turbine.
rugadameghanath
rugadameghanath
Answer 11 years ago
i am using some public transport which will not be affected so give me advises about the dynamo
seandogue
seandogue
Answer 11 years ago
well, an old stepper motor can be used as a generator..then fed to thru a 5V regulator (7805-based or similar or more advanced switching type). I'm not a dynamo specifier, so you'll need to do your own homework on that one. Search the web for "using a stepper as a generator" or use similar terms. that's what I'd do. This stuff isn't a mfg published deal...it's re-engineering product to do what it wasn't made to do, so the specs aren't published for the most part. Maybe someone else has a suggestion of a specific model for your purposes, but I don't. I rather like Lemonie's suggestion m'self.
and7barton
and7barton
Answer 11 years ago
Doesn't matter if you are using public transport !
seandogue
seandogue
Answer 11 years ago
Lol, so true...And it also dawned on me that I read your query sorta backwards...I thought the load was 55A, not 0.55A, even though you said right up front "mobile", ie, cell phone...doh! That's a novel idea you have there!
