99Views7Replies
Author Options:
will this code work? Answered
Q1-here is the code for picaxe 08m2 will it work or something is wrong
Q2-to repeat a code what value do i have to give for the FOR loop i have assumed it to be 0 to 0
THE CODE---------
main: if pinc.4 = 1 then main2
      if pinc.0 = 1 then main3
      if pinc.1 = 1 then main4
      goto main
main2:for b0 = 0 to 0
      play 2,0
      next b0
      pause 2000
      goto main
main3:for b0 = 0 to 0
      play 2,1
      next b0
      pause 2000
      goto main
main4:for b0 = 0 to 0
      play 2,3
      next b0
      pause 2000
      goto main
Tags:picaxe
rickharris
rickharris
Best Answer 8 years ago
Have you tried to run it in the simulator?
Your code runs and I can get it to play all 3 tunes so in that respect I guess it works. (simulated)
As for Q2 you don't need the for next as the tune will play a single run through once it is started automatically.
e=mc^2
e=mc^2
Answer 8 years ago
if i dont use for next then the tune will only play when the switch is pushed but by using for next it will play by 1 switch push(as assumed by me)
rickharris
rickharris
Answer 8 years ago
If I understand what your saying - You don't need the for next loop at all - When a switch is pressed a tune will play.
Once it is playing it will continue until the tune is finished without you doing anything.
Is that what you want it to do.
e=mc^2
e=mc^2
Answer 8 years ago
yes
rickharris
rickharris
Answer 8 years ago
Then that's what it does - at least in the simulator.
e=mc^2
e=mc^2
Answer 8 years ago
can i add ir control to this circuit by modifying the program the new program is as follows
main: irin [1000,main],C.3,b0
if b0=0 then main2
if b0=1 then main3
if b0=2 then main4
goto main
play 2,0
next b0
pause 2000
goto main
play 2,1
next b0
pause 2000
goto main
play 2,3
next b0
pause 2000
goto main
rickharris
rickharris
Answer 8 years ago
Assuming the commands are correct I would think so - You will have to do it and have a go - you may need to make minor alterations as you go along.
