169Views7Replies
Author Options:
will12 volt dc appliance work with 19 volt dc supply Answered
I'm wondering if I can run a 12 volt DC thermoelectric cooler with a 19 volt power supply from an old laptop
iceng
2 years ago
You could run it from a NEW power supply that can deliver a smooth 12VDC...
19V will destroy your cooler, Although it was probably made for a car and as such it may tolerate as much as 15VDC continuously... The 1N4001 diode drops o.65VDC..
19-15=4 Volts too much.. If you put seven diodes in series the 19V will be lowered to 14.53VDC and if the cooler draws one ampere or less...
seandogue
2 years ago
in most cases, no. rarely, a device has a wide input voltage acceptance range, but most times plugging 19VDc into a 12VDc device will result in
a) blown input stages on device.
b) blown output stage on power supply.
c) both.
seandogueseandogue
Answer 2 years ago
and specifically, for the peltier cell, that all depends on the specs for the part. higher voltage means higher current and they have a finite current carry capability...pOof!
Consult tech spec sheets or the mfg of said peltier.
