569Views5Replies
wiring and grounding high voltage transformer?
i need to add another power cord to my HV Transformer it does not look like it has any difference in which way it is wired could i just connect the power cord to it
and in the second picture is the screw the ground to the case or can i just gound the case itself to a pole in the ground for example
10 years ago
Is the primary winding isolated from the secondary.
Steve
Answer 10 years ago
i dont know i cant open it but it is an OBIT
Answer 10 years ago
Measure it with an ohm-meter. You should have NO continuity from one side to the other.
Answer 10 years ago
it has to be isolated because hv supply are pretty dangerous. i had the experience very painful the some veins in my right hand were damaged
Answer 10 years ago
It doesn't HAVE to be isolated, it MAY be isolated, or it may be an auto-transformer.
