3135Views10Replies
Author Options:
wiring?? from WINDMILL to TOWER,How do you keep the wires from twisting inside the tower? Answered
when the wind changes direction, doesn"t the wires eventually twist and bind? Do I need to prevent it from turning 360*
lemonie
lemonie
Best Answer 11 years ago
Slip rings are what you need. Look them up
L
LaMar Solarcabin
LaMar Solarcabin
11 years ago
Slip rings are used but are not necessary on all turbines and I do not use one on mine.
The wind is unpredictable and may blow one way awhile and then reverse and blow the other way so wires won't twist as much as you think they would.
Turbines put on high towers usually have a slip ring just as a precaution because bringing a turbine down to fix it is hard work.
If your turbine is lower to the ground or on a roof you just watch the wiring and if it gets twisted you untwist by hand.
You can see my 125 watt wind turbine and solar system for more ideas:
http://www.youtube.com/solarcabin
robertlelliston
robertlelliston
Answer 11 years ago
Lamar5292... are you the guy that lives in the Uinta's???? IF SO, my wife is goin' to kill us both!!!!!!! I downloaded your book and have been grossly self absorbed in "GREEN ever since!!!   THANK YOU!!!!  Even though I'm still trapped at the bottom of the hill,(Salt Lake) Thanks Again, for your inspiration! By the way, I got my solar panel kit for xmas!
tankman1
tankman1
11 years ago
Why is it lemonie is always there with an answer. Do you thing you are the Instructables police.,no matter who writes an instructable you have some kind of smart remark to make. Do yiou not have a life, do you just sit all day on your PC waiting to punce, and to run someone down.Go and get a life sado! no matter what the subject is you have an answer,
seandogue
seandogue
Answer 11 years ago
Lemonie is just dedicated and interested...You're just rude
robertlelliston
robertlelliston
11 years ago
I feel foulish---I HAVE thought of this but didn't even know what they were called! Thanks for the suggestion
seandogue
seandogue
Answer 11 years ago
Questions are meant to be asked. And ignorance is not stupidity. it's just unfamiliarity...Now if I had asked, then I'd feel foolish :) (and even then, sometimes I forget what something is called)
jxrgen
jxrgen
11 years ago
I have thought of something with a standard audio jack plug (stereo or mono, it doesn't matter), which is placed in the rotation point of the tower.
and7barton
and7barton
11 years ago
I used a gear system to turn the horizontal axis (at the top of the tower), through 90 degrees, transferring the motion to a vertical shaft running down the inside of the tower. The generator sits at the bottom of the tower, with its shaft vertical, and any other gearing (such as reduction gears) sit on top of the generator.
karnuvap
karnuvap
11 years ago
Alternatively limit the rotation of your tower with a pair of stops so that it never does a full circle of rotation. Even if it winds fully round (say) clockwise and hits the stop it will eventually catch a gust onto the vane that will unwind it back into the wind again.
thecookiemonster
thecookiemonster
11 years ago
mabye make a magnetic coupling which connects with metal rings on the windmill? !!! cm
