84Views10Replies
Author Options:
wool : how do i now if it is total wool Answered
Tags:wool
canucksgirl
canucksgirl
9 years ago
I know there's suppose to be a method of burning a sample piece of cloth, where the residual material would allow you to determine the percentage of wool to any synthetics. Unfortunately, I don't quite know what the process is, or what you should look for, but perhaps you can Google it, and find the answer you need.
Denger
Denger
Answer 9 years ago
Try the burn test first: when pure wool burns, it smells like burning hair and leaves a fine powdery gray or whitish ash. Synthetics will bubble or drip and smell like, well, melting plastic, leaving behind a nasty, crusty residue. If the textile yarn in question is mostly wool, (for example 90% wool, 10% Spandex) this can be a bit tougher to determine by just burning, and you may have to resort to steveastrouk's solvent solution, below.
steveastrouk
steveastrouk
9 years ago
As ooposed to containing plastics ?
Dissolve a sample in a sodium hydroxide solution - no sample left, its all wool.
Steve
lemonie
lemonie
Answer 9 years ago
That would probably produce the same result with polyester(?)
L
lemonie
lemonie
Answer 9 years ago
Or Nylon, but you don't tend to find wool / Nylon blends.
L
steveastrouk
steveastrouk
Answer 9 years ago
Some other solvent ?
lemonie
lemonie
Answer 9 years ago
You'd have an elemental-analysis, specifically for nitrogen*.
L
*protein content
Kiteman
Kiteman
9 years ago
Have a go at a small piece with a flame (such as feed the end into a candle flame) - if you get melting, or even dripping, then it's plastic. Pure wool is harder to light than synthetics.
rickharris
rickharris
9 years ago
If you can't tell it doesn't matter!
