5368Views9Replies
Author Options:
would it work to play bass guitar through a car amp/subs?? Answered
i am wondering if i could play bass guitar through a car amp and some subs meant for car audio.
it seems like a shouldnt be able to, but i cant think of a good reason why not...
help?
here are some subs i was thinking about buying... would they work?
http://austin.craigslist.org/ele/1268767456.html
Spentmyrentonabehrenger
So I have a 300 watt Behrenger (sp?) With bass boost amplifier, that sits on a crate halfstack (4-10" subs) anyhoozle the pre amp broke or something and now, there's no sound.... Well if I turn it all the way up I can barely hear anything... My question is can I hook a 140 watt (kracko is the brand) car stereo amp up to the bass head and make it work? Any info on how to make this work would be the shxt!
Thanks
Ne_Nomo
Ne_Nomo
Reply 7 months ago
The signal coming from your bass guitar is in the milliwatts, that's one thousand times smaller than one watt, and your car amp outputs 140 of those. So no, it's not likely that the front end of your (already broken) behringer head was built to handle that much juice. However, your Kracko could service as a less than ideal replacement head until you find a better solution.
dminah_21
dminah_21
3 years ago
It worked for me. I used my bass amp head to drive the car woofers. It actually handles the low B string really well. It produces that actual 31 Hz sound and not only the harmonics that tend to mimic that B. Its really good. I've put a 1/4 jack in the back of it so I can easily take it out of my car just incase I want to use it to add more oomph to my low bass sound..
josh.lawson1
josh.lawson1
6 years ago
See, I'm really tempted to use 6.5" 4 ohm full range car speakers in a biamped bass rig. I have a Carvin Pro Bass 500 that has 2-250 watt@4ohm power sections. I could wire up 4 of these little speakers in a series/parallel configuration and run the crossover at 1,000 Hz. I have a good 15" bass guitar speaker that could easily handle up to 1,000 Hz.....Will this setup work? I'M SURE IT WOULD. Would it work WELL? WHO KNOWS???? I wish I did. I can get all 4 speakers for $50.....
Ezra999
Ezra999
9 years ago
I have recently been thinking of the same thing because i picked up a cheep bass and need a amp..but then im thinking and in the closet i have an 12" dual voice coil alpine type r and a box...i also have a orion colbalt 800.1 mono block amp.
now all i need is a continuous power supply..oh yeah i can get one of those..its a computer power supply...and just wire the right wires to the power, remote and ground on the amp and plug it in the wall...then just have to get a quarter inch to rca to plug the bass in the input of the car amp. i was also thinking of getting a boss equalizer pedal from the local pawn shop so i can change it up a bit in sound...i think this will also work because the sub is dual voice coil and also because on the amp you can switch it between lfp and full, and on full you will get higher frequency through the sub. what do you all think?
orksecurity
orksecurity
11 years ago
Work? Yes. Well? Questionable.
aplauche
aplauche
Answer 11 years ago
do you mean like the tone would suck just cause the speakers arent meant for it, cause thats what i was thinking, but if you used an actual bass amp hooked up to those speakers it seems like it wouldnt sound that bad
orksecurity
orksecurity
Answer 11 years ago
Depends on how loud you want it. Normal stereo speakers aren't designed to drive very low notes at very high volume. You might need something more like a subwoofer.... in which case you might as well just get a speaker made for the purpose.
asdterror
asdterror
11 years ago
Your bass guitar puts out a wide range of frequencies-- the amp has a veritable low pass filter so just set it to the speaker's high-end rating (2k) you would be fine. You might miss those overtones, but you don't want to push the speakers. Try it, at the worst you can bi-amp things later.
