84Views4Replies
xp install help?
ok so i have an xp pro tag on my net-vista and every time i try to install using it it says it is not veiled and i cant get threw install with out it
11 years ago
If you have an XP Pro tag, that means it was factory installed with XP Pro. That key will only work in the OEM version of XP supplied by the manufacturer (and not with a retail XP disc).
Answer 11 years ago
it installed with my old retail disk
Answer 11 years ago
It'll install, but an OEM key (like the one on the tag) will not authorize a retail copy of XP; after 30 days, you'll get locked out. If you used the retail key, you have nothing to worry about (unless, of course, it's registered to another computer).
11 years ago
Are you saying the message says "not valid"? If so then the key code you're typing in is incorrect. Are you sure you are typing it in right?
