Cube Lube
Intro: Cube Lube
in this wonderfull instructable i will teach you to lube a rubik's cube.
STEP 1: Gather Supplies
for this instructable you will need:
1 rubik's cube in need of a lube
1 drinking straw (not the big kind) the bend doesn't matter.
some petroleum jelly
a towel (optional) if you dont use it your rubiks cube will be slicker than snot.
STEP 2: Set Up Cube..
turn the top and bottom layers one half a rotation.
STEP 3: May the Force Be With You.
insert straw into the jelly, when you remove the straw there should be jelly inside it. if you are using a towell wipe the straw, be carefull not to get the jelly out of the straw. insert straw intow the cube, (between the cornerpiece and the center piece. squeeze the straw so that the jelly goes into the cube.
STEP 4: Repeat Step 3
repeat step 3 for each corner, then rotate the left and right halfway. repeat step 3 for each corner.
STEP 5: Work It!
turn the cube rapidly in all directions working the jelly into all the working mechanisms.
STEP 6: Record Your Best Times
leave a comment with how much time you can solve the cube in. or a video. can you beet my time, i bet you can if you try.
171 Comments
k2005770 3 years ago
John_Mobey 5 years ago
Bazinga7 7 years ago
I'm kind of a noob please don't judge my time is 52 secs
Flash67 9 years ago
IsaacL35 7 years ago
argggggggggggggg my best is 35
Tgizzo 8 years ago
FadhilK 9 years ago
i meant piece instead of "pace" in the second line.Stupid keyboard..(:
FadhilK 9 years ago
if u pop out the pieces and "generously" use petroleum jelly{i recommend Vaseline}on all sides of the pace .place it back and try solving it.It'll work like a real dayan 5 zanchi .if you properly loosen the screws of the cube the corner cutting will be great and my record time is 23.47 secs
rippinblaise 15 years ago
SidhantS 9 years ago
Me too.Which algorithm do you find the hardest?
It's the sixth one in my opinion.
technologicalterror 12 years ago
3 minutes 27 seconds
Flash67 9 years ago
Flash67 9 years ago
sgt swagger99 10 years ago
mlai4 9 years ago
ZeroError 13 years ago
Pilgrimm 13 years ago
nickcube4 11 years ago
The Scarlet Tomato 13 years ago
