Cut Any Arbitrary Complex Design With a Craft Cutter
86,364
87
28
Introduction: Cut Any Arbitrary Complex Design With a Craft Cutter
Update:  wow, bummer.  Turns out ProvoCraft (the makers of the Cricut)  sued "Make the Cut" and "Sure Cuts A Lot" so that they can no longer sell their products to work with the Cricut.
Here are some competing products which can be used with Make the Cut software though I have not tried these products specifically, they look like they do about the same thing
Klic-N-Kut computerized craft cutter
Pazzles Inspirationamazon
BossKut Gazelleamazon
USCutter MH/Lazerpoint
I just discovered that the cricut machine can be used to cut arbitrary shapes without having to purchase preloaded cartridges.  This revelation came to me from another instructable:  How to make custom scrabble tiles to whom I am grateful!   A search turns up these other instructables with similar information using different software: create solder paste stencils with cricut, and cut out hearts with cricut
Step 1: Materials
1 craft cutting  machine.  I'm using a Cricut, but because of the lawsuit, you should probably use a different craft cutter, like the brands mentioned on the first page.
Windows computer.  I'm using Windows Vista home edition.  (Please no flack from the anti-windows peanut gallery.  Yes Linux is cool and so is Mac.  Let's all try to get along).
"Make the cut" software.  $59.00  Windows only.  This is what I'll be using for this instructable.  There is a trial version that also works, but creates a big diagonal slash cut through the finished artwork.
There is a competing program called "Sure cuts a lot" that works on MacIntosh, though I have not tried it.  There may be other competitors as well.
USB cable with standard type A and standard type B connectors  (Not included with the cricut.)
USB serial driver which comes with the free trial download of Cricut Design StudioYou'll need to download this in order to get the appropriate USB driver to make this work.  I'm not sure if the driver can be distributed separately.
Inkscape. A  free vector drawing program that lets you work with SVG (scaled vector graphic) files.  You can also use Adobe Illustrator or other programs that can export SVG format.  Update:  Actually the 'Make the Cut' software has it's own vector drawing ability which you can access through the File->Import->Pixel Trace which actually works even better than Inkscape.
Cardstock or bristol board.
Step 2: Connect the Cricut to Your Computer
Connect the cricut to your computer using the USB cable.
Windows will popup a window telling you that it will try to install drivers for the device.  Let it do that.  It actually tries to install two drivers, in my case.
The first driver is a USB to Serial converter which Windows can find for itself.
The second driver comes from the Cricut Design Studio trial which you will need to tell windows about specifically.
You'll also have to use the Cricut Design Studio trial to update the firmware on your cutting machine.
Step 3: Update the Cricut Firmware
All this information is available on line and is highly subject to change, the way that software usually is... but anyway...
Download and install the Cricut "Design Studio" trial
You'll need to download and install the free trial of Cricut Design Studio. This will allow you to do a firmware update and provides the USB driver you'll need in order to control the cricut with your computer.
Reboot and guide windows to the Cricut USB driver
Reboot your computer and windows will ask again about the driver it couldn't find.
Direct it to the install directory for the cricut trial: C:\Program Files (x86)\Cricut Software\Cricut DesignStudio
It should find the driver in there.
Update the Cricut firmware
This is all documented elsewhere online, but generally...
Power down the cricut but leave it connected to your computer via the usb cable..
Launch Cricut Design Studio.
Go to the Help menu and select "Update Cricut Firmware".
Follow the instructions: Hold the Stop button on the cricut down with one finger, then press its power button while continuing to hold down the Stop button for 5 seconds. A loud beep should resound indicating that cricut is ready to receive a firmware update
Select your cricut version and press "Begin Updating Firmware".
Let that finish uninterrupted. It takes a while, maybe about 10 minutes.
Step 4: Convert Your Art to SVG
Scan in your own drawing or find one online.
Update:  Actually 'Make the Cut' has it's own vector drawing ability which you can access through File->Import->Pixel Trace which works even better than Inkscape.  There are video tutorials on line if you need it
Load it into Inkscape.
Select it and choose Path->Trace Bitmap
For this example, I selected "Brightness cutoff" and used the default settings (0.45).  On the Options tab, I played around with the "Optimize Paths" values.  Setting it to 0.20 seemed to work for this particular image.
Press update.  This should create a little outline preview.  If nothing happens, make sure you have the drawing selected.  For me it would get unselected every time I pressed Update.
Press Okay, and you'll see the resulting vectorization applied to your image.  If you don't like it, press Undo, adjust the settings and try again.  (Be sure the drawing is selected).
Close the Trace Bitmap dialog box and drag the vector art aside so you can select your original artwork and delete it, leaving just the vector drawing.  If you like it, save it.  File->Save As.  Give it a name and be sure to type out the ".svg" extension to the name explicitly.
Step 5: Prepare Some Cardstock for the Cutter
The mat that comes with the cricut has a tacky substance on it.   Be careful not to drop it on the floor, it will get coated with whatevers on the floor, like cat hair, for instance.
Lay a sheet of cardstock or bristol board on the mat and line it up as shown in the photo.   The cutter will cut your design starting from the right edge, so line the edge of the paper up over there.
For this particular sheet of bristol board, I adjusted the knife dial to the "2" setting.  At the "1" setting, it did little more than score the cardstock.
Line up the mat alongside the plastic guide and press the "load paper" button.
Be sure to leave space behind and in front of the machine for the mat to slide back and forth as the cutter is working.
Step 6: Load the SVG Artwork Into MakeTheCut
Launch "Make the cut" and choose File->New and then File->Import->SVG.  Browse to your file and click open.
Grab the little lower left corner red arrow and stretch the design to fit.
Step 7: Cut Out the Design
If the installation went smoothly, you ought to be able now to just select "Cut Project With..."->Provo Craft Cricut.
I chose the "optimal" speed rather than the default of "fastest".
Press start and it will begin cutting out your design....
when it's done cutting, press the "unload paper" button to release the finished piece.
Step 8: Remove the Cutout From the Mat Carefully
When the cutter has finished cutting out the design, remove the cardstock from the mat carefully.  Go slow, especially if the design is intricate.
Step 9: All Done!
The finished cut out.
Incredible.  This tool is so awesome I can hardly stand it.  It's almost like having your own laser cutter - but it only works on paper.  Maybe someone out there will hack a laser into it?
Epilog Challenge
Epilog Challenge
Be the First to Share
    • Plastic Contest
      Plastic Contest
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    28 Discussions
    huangt2
    huangt2
    4 years ago
    I downloaded Easy Cut Studio for a few months and will look again at options then. But for now i'm happy! it is a good way to cut out complex shapes. You can download the trial version from http://www.easycutstudio.com/
    BillD80
    BillD80
    4 years ago
    I WAS a hard core Cricut fan prior to lawsuit ProvoCrap's machines used to be able to cut heavier materials and tough materials better than others When people used MTC and SCAL, people didn't buy their expensive cartridges ProvoCrap lost a lot of customers because of the suit What we want to cut is our business
    I had SureCutsALot and MTC already The older versions work great with older Cricuts that do not have firmware upgrades to later Provo firmware Once upgraded to their Latest version, MTC and SCAL will no longer work with either Provo put blocks in firmware to prevent other software
    If you're lucky enough to have early firmware and early versions of MTC or SCAL, Even a demo version, Cricuts now cheap, become a low cost way to cut your own stuff I do all the design in new versions of software and save copy as earlier flat design. When I'm ready to cut, I open the flat copied design into early version of MTC which can still cut with my old Cricut
    ctdahle
    ctdahle
    5 years ago on Introduction
    You have written a wonderful Instructable.
    It is disgusting that ProvoCraft has responded to people who WOULD have been a powerful sales force by extending their giant middle finger.
    I bought the machine planning to use it to create model railroad buildings and scenery from card stock, a use which was completely possible until ProvoCraft sued the third party software creators and locked down the Cricut machine so that customers cannot cut out their own original artwork. This is one of the sleaziest acts of corporate arrogance I have ever seen.
    I hope that some lawyer out there is working up a class action that drives them not only into bankruptcy, but also eternal despair.
    Browncoat
    Browncoat
    5 years ago
    Has anyone figured out a way to do this sort of thing since the original software won't work any more?
    foobear
    foobear
    Reply 5 years ago on Introduction
    The version of the Make the Cut installer that used to work was 3.2.0. So... if you can find that one you might be halfway there. I'm not sure about the firmware part though whether that is still available somewhere. Good luck.
    foobear
    foobear
    The cricut firmware it uses is::
    Cricut Expression 2.3.4
    Cricut Create: 1.5.4
    Cricut Personal Cutter: 1.3.4
    Browncoat
    Browncoat
    5 years ago
    hardlec
    hardlec
    8 years ago on Introduction
    I was going to purchase a Cricut. That won't happen now. I am looking for a good way to cut out complex shapes.
    arrrrgon
    arrrrgon
    9 years ago on Introduction
    After you have done this with your Circut are you able to still use your cartridges?
    foobear
    foobear
    I'm sorry, I just found out that the makers of the Cricut (ProvoCraft) sued Make the Cut software so that this solution won't work anymore.
    67spyder
    67spyder
    I am bewildered at a company that wants people to NOT use their product (I know their short sighted thought is that they will sell more of their cartridges). I was ready to go buy one on sale at wal-mart till I found out how restricted they are. (not a shot at you or your instructable, just lamenting ProvoCraft's closed thinking)
    pmowers
    pmowers
    The SCAL software interfaces through the Cricut's USB port (the reason that you need the design software is for the windows drivers). It does not modify the Cricut in any way, so the cartridges still work.
    foobear
    foobear
    That's a good question. I never wanted to use cartridges with it, so I haven't tried. I will try out the cartridge that came with it (if I can find it) and let you know.
    mooseplatypus
    This looks fantastic, It would be great for getting rid of the frustrating fiddly stencil making step during silkscreening. A Craft Cutter and make the cut software has officially been added to my wish list!
    gtoal
    gtoal
    9 years ago on Step 9
    A very easy next project, having got to this stage, is to use your cutter to etch glass. Cut a shape (eg someone's name) out of contact paper vinyl (much cheaper in big rolls from Walmart than the stuff that's sold custom for Cricut, and for many projects it works just as well) and then keep the hole (as in the image above) rather than the cut-out letters. Attach this to something like a 1 pint beer mug (must be a smooth cylinder, and not have lumpy bits!) as a mask, and paint the glass that's exposed with a special glass etchant available from Hobby Lobby, Michaels etc. In about 6 minutes hose it down with the garden hose and remove the vinyl - you have a nicely etched beer mug with someone's name on it, ready for a Christmas present! Fast and cheap, and looks great!
    (WARNING: The etchant is based on hydroflouric acid and must be handled with adult care.)
    gtoal
    gtoal
    And done, just in time for a New Year's pint :-)
    https://www.instructables.com/id/Easy-glass-engraving-with-the-Cricut/
    gtoal
    gtoal
    9 years ago on Step 5
    Great to see the floodgates have been unlocked and Cricut instructables are appearing! Thanks, JL! Just placing a reminder here for a later instructable on how to refresh the sticky mats rather than buying new ones. Until then - if your mat dries out, another option is to spray the back of your card with something like artists spray mount from 3M.
    foobear
    foobear
    that sounds good, I can how the sticky mat might get less tacky over time. Mine has already collected cat hair and little bits of paper and dust and who knows what all over it! I've no idea how to handle it. =)
