Dash Led Mod
Intro: Dash Led Mod
ever hate the junky green dash light you car came with? here is one way to get rid of them and still see your dash at night.
first select a dash to mod... this one will do.
note just because i post this does NOT imply liability on my part you must work safe. and any time you work on a car disconnect the battery!!
STEP 1: Open Your Dash
yeah open it up and save the screws. you'll have a nice hole where a gauge cluster was. it is WAY easier to just pull it out.remove the old bulb's and any screws that hold the flexible circuit board to the back of the cluster.
now get out your drill and drill-out the "spot welds" so you can remove the cover(white part)
STEP 2: Selcting Light's
about lighting. THIS IS VERY IMPORTANT! blue light's cut down your ability to see in low light worse than anything else! this is why dark room's ALWAYS use red light's. this is why i chose to use these. plus the fact that they cost only $6.00 for three! now that you've drilled out the plastic welds you'll need to remove the green plastic color filter.
wiring is easy black goes to ground/red goes to a switched power point(i.e. an unused accessory lead in the back of the fuse box)or the wire that goes to your head light switch to control your dash light's.
STEP 3: Reassemble
in this mod i removed the #@%ing red stickers.and painted the well black. that alone makes it easier on the eye's! now you might notice three small red light's this is a day time(with flash)picture. next pic is at night wile blury it shows that they are plenty bright enough!
35 Comments
Dakota Joel98 9 years ago
AWESOME!!!!!
Azzurro 9 years ago
is that a golf 1? :D
schitzo69 12 years ago
Sym 13 years ago
Red lights are still in place in alot of military flight-stations but I have found the pilots tend to use dim, white lights more than the reds.
The Red Myth:http://stlplaces.com/night_vision_red_myth/
yo man 14 years ago
can you use other colors like blue?
wi-fi astronomer 13 years ago
slideways 14 years ago
i would like to see some pic's when your done modding! your avitar leads me to think your going to do this to an atv?
yo man 14 years ago
godofal 14 years ago
if u look around the internet (ebay) u can get them for like 10-20cents each...
even if you order in quantities like 10, theyr 20~30 cents each. (plus costs to ship, but theyr neglectable)
but for like 20-30bucks leds at one dealer and you got them really 10 times cheaper than that!
Foaly7 14 years ago
Paulkartking25 14 years ago
Mr. Thumbs 15 years ago
TheGreatMaster 14 years ago
That is why it has been preferred by army. But what is the reason it is there on the top of the politicians car.
Start Racing at Farringdon Motorsport Limited.
pdlbooboo 15 years ago
protocolZA 15 years ago
slideways 15 years ago
trayo 15 years ago
https://www.instructables.com/id/Replace-you-cars-instrument-panel-lights-with-LEDs/
trayo 15 years ago
