Digital Camera Spectroscope
Intro: Digital Camera Spectroscope
This simple mod allows the slide to be mounted to most cell phones, turning them into digital spectrometers.
How-To
How-To
STEP 1: Salvage Springs From an Old Floppy Disk
You need four floppy disk ( 3"1/2).
STEP 2: Modify Springs
With a pince, modify springs to get arms parallel. Do it for each spring
STEP 3: Use an Old Photo Slide
open it.
STEP 4: Soldering Springs
with a candle ( or something else ) turn springs very hot ( red ), and quickly solder it on the slide.
put glue on each spring ( and in all corners )
STEP 5: Side2
close the slide with the other part. Press it for 3 seconds.
STEP 6: Rubber Band
take an old mouse pad and cut four parts ( 1cm x 4.5cm )
STEP 7: Glue Rubber
put one rubber part under spring. put glue. put the second part on it and press hardly for 5 seconds.
do it again.
do it again.
STEP 8: Finish !!!
now you finish it ...
STEP 9: Diffraction Grating Slide
put a diffraction grating slide in front of it ( glue or other ).
STEP 10: Be Mounted to Most Cell Phones
you can use it on most cell phones
STEP 11: Make Spectro Picture
Now you can make this kind of picture
24 Comments
wgrube 14 years ago
alltootechnical 13 years ago
coonass 16 years ago
blakeredfield 15 years ago
EcoMotive 16 years ago
Kent 16 years ago
mju.cat 16 years ago
chooseausername 16 years ago
Meispantyshot 16 years ago
dorejc 16 years ago
I did not read the bottom of the page .......... :o/
So yes, in that case, 5 euros is a better price ! =o]
BlueFusion 16 years ago
About "RGB filter", I wanted to mean "Color filter mosaic" or "color filter array" of course : Each pixel of the sensor having a different color filter (R, G or B).
I know that the human eye uses a similar method.
But like I explained in my next comment (the one with bold writings), if I said that, it's because I've personally noticed that none of my cheap DC or Camcorder were able to capture spectra correctly (ie, captured spectra were less complete than when I watched them with my nude eyes).
For instance, a captured spectrum of the direct sun-light (which is supposed to display some absorption lines) had a giant hole between one or several narrow B strips, and an incomplete G band, etc ... It looked like the spectrum of a fluorescent lamp.
My interpretation of this phenomenon :
- R, G & B filters used by the sensors of my DC and Camcorder are of a too bad quality (narrow B filter, composite G filter, and large R filter), and I've wrongfully generalized by saying that color sensors were unable to capture complete spectra ...
Then, DoreJC sent me a private message and gave me a link to a French site showing some very complete and perfect spectra captured with a simple webcam. And that's how I went to the conclusion that my cheap DC and camcorder must be really terrible ...
J'ai eu votre message.
About my previous comment, I wrote that because I failed to film or photograph a full spectrum using my digital camera (Kodak C310) or my camcorder (Samsung VP-D371).
Au sujet de mon prEcEdent commentaire, j'ai Ecris cela parce que je ne suis pas parvenu A photographier un spectre complet avec mon APN (Kodak C310) ou mon camescope (Samsung VP-D371).
So I guess that some cheap DC and Camcorder will not make it ... unless we want inaccurate spectrum ...
Donc je suppose que certain APN et Camescopes bon marchE sont A dEconseiller ... A moins de vouloir des spectres incomplets ...
Just for reference, could you, please, tell us what device you tested it on ?
Juste pour rEfErence, auriez-vous, s'il vous plait, l'amabilitE de bien vouloir nous indiquer les appareils sur lesquels vous avez rEalisE vos tests ?
=o)
dorejc 16 years ago
das300 16 years ago
cvxdes 16 years ago
rusty0101 16 years ago
andrew_29 16 years ago
