Altoids Tin S'Mores Pocket Snack Kit
Intro: Altoids Tin S'Mores Pocket Snack Kit
If you crave melted, gooey chocolate & marshmallow with the graham cracker crunch of s'mores, now you can take some with you wherever you go! It's so easy and fun to put these together. You'll have s'mores in no time.
Perfect to use on ebqbbqmaster's fabulous eBQ as seen here.
https://www.instructables.com/id/Make-your-own-eBq-BBQ-Grill-out-of-an-Altoids-box/
Or lo-tec's Alcohol burning stove as seen here.
https://www.instructables.com/id/Altoids-Tin-Alcohol-Stove/
If you don't have an eBQ or Altoids tin stove to fire up, you can walk around with this in your pocket. It will melt just right, after about 1/2 hour or so on a hot day. Or put on hot asphalt, on top of a gas or electric burner, under the broiler, in the engine or dashboard of a car, on a heater or wood stove or propane torch Always cook with common sense and caution!.
In any case it is sure to bring smiles and s'more smiles! Grill on! It's just the right size for one, so bring two! To share! All you need is a tin, parchment paper or aluminum foil, graham crackers, chocolate squares, mini marshmallows, an Altoids tin stove or grill, hot pocket or other heat source.
STEP 1: First, Line Tin.
STEP 2: Add the Crunch First!
STEP 3: Gooey Goodness
STEP 4: Top It Off!
STEP 5: Close, Cook, Enjoy!
Alternatively, you can torch the top of the marshmallows with a flame (propane torch) until they burst into flames. Snap shut the lid tight and carefully. Let sit until cool enough to handle. Open, eat and enjoy!
STEP 6: Help Me Win by Voting
Leave any comments and rate. I really appreciate it! I had fun putting this together. Enjoy!
18 Comments
theRIAA 14 years ago
selkie 11 years ago
Vegan marshmallows are a bit more fragile than regular ones so roasting on a stick isn't a great option.
KNEX BUILDING IS FUN 14 years ago
Nil Sty 13 years ago
lalaluluj 14 years ago
Safemac 14 years ago
Wafflicious 14 years ago
BLASTFEMI 14 years ago
kevinkm77 14 years ago
mason0190 14 years ago
Cervantes 14 years ago
Flashflint 14 years ago
