Easy Plastic Rivets
3,825
15
6
Introduction: Easy Plastic Rivets
Here's a really simple way that you can do some plastic welding with weed eater trimmer string and a soldering iron
Step 1: Materials
soldering iron
two plastic or lightweight materials to join together
be sure to do this outdoors as the fumes are peculiar and probably not good for you.
Step 2: Make a Little Hole
make a small hole to hold the rivet that will join the two pieces together.
you can use a drill, or if you are using plastic, you can use the soldering iron
Step 3: Make One Side of the Rivet
feed a bit of trimmer line through the hole.
using the soldering iron, mash the plastic down around the hole. If your soldering iron has a low setting, try that first.
Step 4: Complete the Rivet on the Other Side
turn the piece over and complete the rivet on the other side
Step 5: A Light Duty Bond But It Works
the rivet holds pretty well, but can be torn apart with a bit of effort.
Be the First to Share
    • Holiday Decorations Speed Challenge
    • Plywood Challenge
      Plywood Challenge
    • Battery Powered Contest
    6 Discussions
    zume
    zume
    9 years ago on Introduction
    would this be possible with plastic barrels, welding them end to end?
    foobear
    foobear
    I think you would need a stronger plastic to rivet with in that case... Not sure, let us know how it turns out
    O.K I'm just going to publically announce, that I don't know what a rivet is. There, I did it. Please be gentle with any response. I also don't understand what the finished product is and how it works. Remember, there is a "be nice" rule people pulleassssse
    foobear
    foobear
    Oh yeah, I guess it's not very clear. That thing I was working on was an instructable that didn't work out. So I never did publish that or explain what it was. The general point of this instructable though was the discovery that I could make plastic rivets out of weed whacker wire. Rivets are just something that can hold two things together. Usually they are made of thin metal pipe.
