Felt Beads TUtorial
Intro: Felt Beads TUtorial
Queres hacer bolitas de fieltro?
Do you like felt beads?
STEP 1: Felt Beads
Dip your dry pompom in water and add some dishsoap...
Sumerje el ponpon en agua, o mójalo con agua y una gota de detergente.
Then strat to rolling it between your palms... roll gently, no pressure until the core is firm, rolling in different directions so all surfaces get equal time felting. Once a nice round ball is forming slowly add more pressure.
Después empieza a moldearlo entre tus manos, suavemente, girando la bolita entre ellas, sin mucha presión inicialmente, hacia todos lados para que quede enfieltrada pareja. Después que ya tiene la forma tu puedes ejercer más presión y darle el tamaño que deseas.
And it's ready!.. you have to wash the ball and then you can use or dye it.
Y listo! lavas la bolita para sacar el detergente y la puedes teñir o lo que quieras...
10 Comments
JuliaS4 9 years ago
An interesting idea for beads.
What better to take carded wool or merino?
Quadro313 16 years ago
vivabear 14 years ago
I discovered this after I accidentally machine washed my hat with a fur ball on top and it turn into a little felt ball. I just have to give it to my cat to play = =
Feltyfriend 14 years ago
ivoncita 16 years ago
Mica 16 years ago
Tool Using Animal 17 years ago
Verrito 17 years ago
theRIAA 17 years ago
rimar2000 17 years ago
