Introduction: Filament Cleaner Cheap and Easy
This tutorial is about an very cheap and quick to build filament cleaner.
It is made out of:
- One clothespin
- A small chunk of a kitchen wipe
The only tool that is needed is a scissors or a sharp knife
Step 1: The Materials
As told in the discription, on the photo You can see everthing You will need for this hack.
- One clothespin
- A scissors or a sharp knife
Step 2: The Cutting
You have to cut out an rectangular chunk out of the wipe. It has to be a little wider then the clothespin and should be as long as ist. As you can see on the pictures.
Step 3: The Building
Now you have to fold the chunk some times and put it in the clothespin. (It could be necessary to adjust the accurate dimensions of the chunk. But where the first chunk came from, there will be more...)
Step 4: Finishing
Now You can clip Your new filament cleaner dircet to the filament just in front of the feeder. It should make no difference between a bowded or a direct drive system.
![3D Printing Contest](https://content.instructables.com/F4S/K35J/I7XQYWVM/F4SK35JI7XQYWVM.png?auto=webp&frame=1&width=320)
3D Printing Contest
