Introduction: Ft-ible Halloween Models
Create spooky Halloween models using fischertechnik elements!
I play with different educational manipulatives for a living. (Visit www.weirdrichard.com). Over the years I have built different holiday themed models using all sorts of toys.
Here are a variety of spooky fischertechnik ghoulies and goblins for your enjoyment!
Note: The CAD looking images were generated by LDraw/MLCAD and a fischertechnik elements library.
Step 1: Ft Bat
The elements you need are:
8 Angular Block 60 Degrees
6 Angular Block 30 degrees
6 I-Strut Yellow 30
4 Angular Block 7.5 degrees
1 Angle Girder 7.5
4 Angle Girder 60
2 Angle Girder With 2 Pins
2 Angle Girder 30
18 Single Rivet 4
1 Building Block 5 with two Pins
8 X-Strut 42.4
Step 2: Ft Monster
10 Angular Blocks 60 Degrees
10 Angular Blocks 30 degrees
5 Link 15s
2 Spring Cams
20 Building Block 30s
4 Building Block 15s
6 Angle Girder 15s
1 Mounting Plates 15x15
Step 3: Ft Skeleton
5 Link 15s
2 Spring Cams
3 Building Block 15s
6 Building Block 15 with 2 Pins
2 Clip Axle 45
3 Clip Axle 60
3 Clip Axle 90
8 Axle Couplings
1 Clip
2 Single Rivet 4
2 Building Block 5s
4 Building Block 7.5s
4 Clip 5s
2 Rope Pulley 12s
Step 4: Ft Zombie
5 Link 15
2 Building Block 15 with Counterbore
14 Building Block 30s
9 Building Block 15s
4 Single Rivet 4
DIY Halloween Contest
