Great Looking, Inexpensive Computer Desk
Intro: Great Looking, Inexpensive Computer Desk
When looking for a computer desk for my home office, I couldn't find anything that was reasonably priced and met my needs. All of the nicer desks I was looking at were at least $1200 or more and weren't exactly what I was looking for. I also didn't see a lot of instructables for desks, so I decided to build one and set myself a budget of $300.
The desk consists of four pieces.
- table top
- 3 drawer cabinet (writing supplies, computer cables, etc)
- 2 drawer file cabinet (drawers are sized for hanging file folders)
- printer cabinet
I chose to build it this way because it is easy to transport, and it can easily be shifted around to a new room if I chose to move at a later time. I also chose a fairly simple construction, no crazy joinery, and tools that every basic wood shop would have.
Materials:
- 3 (4'x8') sheets of 5/8" mdf (I would have liked to use maple veneer plywood, but its about 3 times the price)
- 2 (4'x8') sheets of 1/8" mdf or hardboard
- 1" brad nails
- 5/8" brad nails
- wood glue
- wood filler (for nail holes)
- 5 pairs of roller tracks for the drawers
- 7 drawer handles
- 1 pair of cabinet door hinges
- 1 gallon of primer
- 1 gallon of paint
- brushes and rollers
Feel free to build as many or as few cabinets as you need to suit your application. And if you build one post some pictures!
- table top
- printer cabinet
Materials:
- 1" brad nails
- 5/8" brad nails
- wood glue
- 7 drawer handles
- 1 gallon of paint
STEP 1: Necessary Tools
I wanted to post this instructable using common tools. These tools are very common and for the most part inexpensive. Chances are if you don't have all of these tools, your neighbour will be able to help you out.
The tools I used were:
-drill
-table saw
-miter saw
-tape measure
-adjustable square
-paint brush and roller
-brad nailer
-cutting pliers
-drill bit and driver
-screwdrivers
-palm sander
-drill
-table saw
-miter saw
-tape measure
-adjustable square
-brad nailer
-cutting pliers
-screwdrivers
-palm sander
STEP 2: Cut the Pieces
Using a table saw, cut all of the pieces to size.
Laying out your cuts effectively will save you a huge amount of time in the end. I would recommend that you make all your table saw cuts first, then trim the pieces to size on a miter saw. On top of making it easier and faster, it will also save a lot of material.
Programs like cutmaster2D allow you to type in the dimensions of the pieces, and it will figure out the best way to lay out your sheets.
The pdfs show the pieces and dimensions.
STEP 3: Assemble the First Cabinet
Here is an exploded view of how the pieces go together.
The pdf also has dimensions.
STEP 4: Assembly Continued
With glue and a brad nailer assemble the cabinet.
Build the box first, then attach the middle braces, and the top and bottom trim.
The two drawer, and three drawer cabinets are almost identical, other than the spacing of the drawers.
STEP 5: Printer Cabinet
The printer cabinet is almost the same as the two and three drawer cabinets, with some minor differences.
- there is no bracing for drawers,
- there is a bottom piece for the printer to sit on (which is braced from the bottom)
STEP 6: Build the Work Surface
The table top I built is 8' x 2' which fits my office nicely. 2' is plenty room for a keyboard and flat screen monitor to fit.
Use the table saw to cut strips of mdf to build the interior of the table top.
Glue and brad nail the structure together for a thick and strong, but light table top.
STEP 7: Build the Drawers
Here is an exploded view of the drawer, along with the dimensioned drawing.
STEP 8: Build the Drawers (continued)
The drawer construction is fairly simple.
Assemble the four walls of the drawer by gluing and brad nailing a simple butt joint.
Mark the overhang of the drawer front to ensure that it is centred before gluing and nailing. Nail from the back, so you don't have to spend time covering the nail holes later on.
The final step is to glue and nail the bottom of the drawer (1/8" mdf).
STEP 9: Printer Door
I built the printer door to look like two regular file drawers.
Cut two drawer fronts as well as a strip for the middle, and attach them to make it look like a drawer front.
STEP 10: Fill the Nail Holes and Sand the Corners
Fill the nail holes with wood filler, and sand off the excess once dry.
It is also a good idea to take a sander to the hard edges to round them just a bit.
STEP 11: Prime and Paint
The mdf is pretty porous so it will take a few coats to completely cover. I would recommend at least two coats of latex primer before two final coats of paint.
If you have access to a spray gun you will get a better finish, but using a roller and a brush works just fine.
STEP 12: Attach the Handles
Take some time to choose the right hardware. The handles you choose will really set the look of the whole desk.
The handles I chose were the most expensive part of the desk, at about $80 for all of them, but to me they were worth it!
I used a cardboard template to mark the holes of the handle. I cut a notch in the centre of the template, measured the centre of the drawer front, and drilled through.
STEP 13: Drawer Tracks
Screw the rollers onto the drawer bottoms.
Then screw the matching pieces to the inside of the cabinet.
41 Comments
HilaryH5 8 years ago
What nonsense. I don't want to install software to get the plans. Seems like a scam to get you to download unwanted software on your computer. Why can't I just download the pdf?
claudg1950 10 years ago
I copied the type of handles you used, the trimming for the drawers and the desktop, and the general idea.
Just for the record: The 60x175cm desktop (24x69 in), the 40x50cm (16"x 20") cabinet and drawer`s sides and back were all made with 15mm (5/8") white melamine. The trim for the cabinet and the table top is some inexpensive 5 cm (2") wide softwood door molding. The bottom and face of the drawers is 9mm (3/8") MDF.
Strip moldings and MDF were stained with a water-dissolved powdered pigment (in fact, brown pigment for fabrics, as I couldn't find true wood pigment). Notably, by brushing the pigment horizontally the illusion of wood grain appeared (just a fluke).
Thank you very much indeed for your inspiration and your instructable.
phish814 13 years ago
Drojen 13 years ago
We changed the dimensions a bit since we used 1/2" MDF instead of the 5/8". We also used a hollow core 24" x 80" interior door slab for the top and made two simple cabinets with hinged doors based on the printer cabinet plans you made. To those I drilled some holes on the inside for adjustable shelf brackets and cut some simple shelves for extra storage. I've attached some pics below.
Once again thanks!
charliejaime 13 years ago
Thanks for any answers/help you can provide a newbie.
CJ
Drojen 13 years ago
On the door side, you have to use a forstner bit to drill out the hole to mount the hinge. The hinges come with handy little templates that make it easier. I got everything at Home Depot. They basically just sit inside the hole you just bored out and are anchored by a couple of screws. Just go slowly so you don't bore all the way through the door face.
For the shelves I just drilled some holes in a line and put in some of those little adjustable shelf brackets like you find in store bought bookshelves. They just pop in and out so we can adjust accordingly. Eyeball your drill bit and the side of the cabinet box and then put some tape around the bit to mark the depth so you know when to stop drilling so you don't pierce through. I put the holes about 1.5" apart. Just make sure the front ones are level with the back ones, mark everything out, and go to town.
The cabinets are 20" on the inside, 21" on the outside, and 22" where the trim pieces go on the top and bottom. They are 28" tall. The construction is the same as the printer cabinets in this instructable. Since I used 1/2" MDF, I used rounded off measurements to make it easier.
I hope this helps, good luck.
Jason
Thanks for your detailed response, I greatly appreciate it. I will let you know how I make out.
Happy New Year!
CJ
kyzla 14 years ago
my printer is very differently shaped :( but has a scanner and fax and printer all built in :)
i think i could, and then adjust the size in the plans and all, and adjust the top and such... i don't think it'd be too hard, do you?
also: GREAT job. i grew up watching my grandfather see a problem and fix it by building some custom piece of furniture. they were works of art, and easily replicable with plans and everything. yours is just wonderful. 5 stars!
looker1995 14 years ago
clintiepoo 14 years ago
porcupinemamma 15 years ago
silver912targa 15 years ago
Nymph 15 years ago
jmthomas 15 years ago
Spokehedz 15 years ago
nickfarnell 15 years ago
choch 15 years ago
