Introduction: Guitar Body Picture Frame
its pretty simple , select a piece of wood for your project , i used the top of an old wokbench .
 i havent stained it or painted it yet i just cant decide what colors i should use if any . my woodworking skills are preschool at best an im deff happy with the end result so its not tough you just need focus .
Step 1:
select a piece of wood , i used the top of an old work bench , i had to use a router to clean up the piece before i did any work i reccomend using a fresh piece so this step can be skipped.
Step 2:
trace the desired guitar on the wood an cut out using a bandsaw
Step 3:
mark where you would like to put the recesses that will contain the pics use a router to remove a 1/4 in recess an then use a chisel to square eveything up
Step 4:
you can skip this step if you want but it helps with the look select a router bit an go around the outside edge
Step 5:
sand the entire project to remove any blemishes in this step you will be able to sharpen up the curves an edges
Step 6:
now you could paint it stain it or leave it the way it is . i added a few lil knobs i made from scrap wood an lag bolts i even made a fake on off switch ill prob stain it i haven decided yet  but enjoy an lemme see some of your works !
Holiday Gifts Challenge
ShopBot Challenge
ShopBot Challenge
