Hack an Inexpensive Doll to Be Poseable
31,290
50
31
Introduction: Hack an Inexpensive Doll to Be Poseable
I have noticed a strange inequity between the poseability of girls and boys dolls.  Most of the female dolls have stiff arms and legs which permit them to do little more than model clothing.   To rectify this, I will attempt to turn a very cheap Dollar Tree girls toy doll into a fully poseable action figure.
Step 1: Materials
doll from the Dollar Store ($1 each)
super glue (also $1 at the Dollar store)
hot melt glue ($1)
florist wire ($3)
clamp
hand drill
pin vise
hot melt glue gun
pliers for bending and cutting wire
very small drill bits (as thick as or smaller than the florist wire)
optional:  hot knife for cutting plastic
sculpey
sculpting tools
Step 2: Disclaimers and Various Warnings
Once complete, this doll may not be suitable for young children.  There is a good chance that one of the dolls parts may come off, exposing possibly sharp wire which could cause injury.
When cutting plastic with a hot knife, make sure a window is open and there is good ventilation.  Better yet, do that part outside, the vapors are probably not good for you.
Step 3: Knees, Ankles, Elbows and Wrists
The following sections might be disturbing to little kids, so you might want to do the doll surgery when they are not around...
Using the jeweler's saw (or a hot knife), separate the doll arms and legs into sections at the knee, ankle, elbow and wrist.  Try to create the knee and elbow lines symmetrically so they line up evenly in the final assembly.
Using the pin vise, create a starter hole in the center of the leg.  Then use the hand drill to slowly drill out a hole about a half inch deep in the center of the lower and upper leg and lower and upper arm.
Do the same for the feet and hands, but make the hole only a quarter inch deep.
Go slowly when drilling the forearm and ankle.  The plastic is very thin and it's easy for the drill to get off center and go out the side instead of straight down.
Step 4: Joints
Apply a bit of super glue to the end of the florist wire and insert it into the hole as far as it will go.  Allow 15 seconds for the glue to set before handling again.
Trim away excess wire, but leave at least 3/4" extending out of the hole.
Connect the upper and lower legs and arms together with the florist wire and super glue.
Step 5: Torso
Remove the head and use the jeweler's saw or hot knife to cut away the ball joint of the head.
Remove the arms by pulling them off.  They should come off easily.
Cut the hips away from the torso at the waist.
Cut the legs away from the hips by passing the saw blade through the hinge.
Step 6: Reattach the Legs With Wire
Thread a length of wire through the hips as shown in the first photo.  Try to hook it around the internal support rod for added strength.
Drill holes in the upper part of the legs as shown.
Line up the legs with the torso and trim the wire to the appropriate length.
Apply super glue to the ends of the wires extending from the hips and insert into the upper leg holes.  Allow to set 15 seconds.
Step 7: Reattach the Arms With Wire
Preparing the arms for reattaching is the trickiest part.   Drill a hole vertically through the top of the upper arm.  Then drill a small hole perpendicular to the vertical hole as shown in the first photo.
Work a long length of florist wire into the side of the upper arm as shown.  You may have to curve the wire slightly to get it to go in and down into the vertical hole.  Once the wire is worked in as far as it will go, remove it, apply glue and reinsert it.  This is the hardest part.
Thread the arms into the torso by passing the length of wire through the holes at the armpits.
Set the torso aside.
Step 8: Prepare the Head for Reattaching
Prepare two long lengths of florist wire.  These two lengths will extend from the tip of the head to the bottom of the hips.
Invert the head and fill it up with hot melt glue.
Insert the two lengths of florist wire into the head as far as it will go.
Set the head aside until the glue sets.  Check for drips and remove them when the glue is cool enough to touch.
Step 9: Attach Head to Torso
Thread the wires extending from the  head through the neck into the torso.
Be sure the arms are threaded in fully.
Invert the torso and fill it up with hot melt glue.  This will secure the head and arms to the torso.
Step 10: Attach Torso to Hips
Thread the wires extending from the torso into the hip cavity.  Trim to fit as necessary.
Fill the hip cavity with hot melt glue.  Thread the torso wires into the hip cavity.  Set aside until the glue sets.  Check for and remove drips when the glue is cool enough to touch.
Step 11: Optional: Head Sculpt
Maybe try and make a head sculpt and see how it turns out.
Using a hot knife, remove the face from the doll head as shown.
Fill the void with sculpey (skin colored sculpey would be best, but I don't have any on hand).
Try sculpting a face, just for fun.
I have no idea how I would cure the sculpey with the hair attached like that.  I don't think the hair or the plastic would survive in the oven.   Sculpey is probably not the right choice here.
Step 12: She's Ready for Robot Chicken
Thanks for reading!
Joby Transform It! Challenge
Craftsman Tools Contest
Epilog Challenge
Epilog Challenge
Be the First to Share
    • Plywood Challenge
      Plywood Challenge
    • Battery Powered Contest
    • Plastic Contest
      Plastic Contest
    31 Discussions
    arawn
    arawn
    11 months ago
    Great idea, can't wait to try it out.
    moonshinesoo
    moonshinesoo
    2 years ago
    Thanks! I have often noticed the disparity between available m/f genuinely passable dolls. I need a good one for life drawing myself. you have given me some real food for thought.
    DOLLC1
    DOLLC1
    4 years ago
    How can i hide the seems??
    scooterdad
    scooterdad
    4 years ago
    Hi, i cant imagine you expected this to be contantly pulled about , but its a great tutorial, really well laid out and wil be great for anyone wanted to use dolls in photograph work. i love modding dolls. i generally make them a bit creepy.
    foobear
    foobear
    Yes, air dry clay is a good idea. I have a strange fear of it though...
    Are those Barbie faces? wow, that's crazy
    Grafton
    Grafton
    Maybe you can oil the faces so that your sculpy will pop off so you can then bake it and glue it on. Or seal over the faces with plastic wrap and sculpy over that so the new faces can be popped off for baking.
    foobear
    foobear
    I was able to widgie the sculpey face out of the rubber head enclosure after a few days. I'm planning to bake and paint it soon. thanks!
    Thrasym
    Thrasym
    I'm a little late to the party but I'm curious. Did the plasticizers in the polymer have any affect on the head? It seems to affect just about everything I've put it on (or its box) that has anything even close to any sort of plastic/rubber component (given enough time).
    foobear
    foobear
    I mean of course, crazy in a good way. Wow
    insomniaSAH
    insomniaSAH
    overtime though, wouldn't flexing of the joints cause the wire to snap or break from use?
    Ball jointed dolls, which boast a high range of poses use a system of elastic or other stretchy material (sometimes even metal springs!) attached too loops at the extreme joints (Wrists, ankles, neck) and pulled all the way through the limbs to be anchored in either the hips or the torso.
    The tension allows for the limbs to be posed in all manner of ways, and if the elastic breaks, it's easier and I would think probably safer to replace than small bits of metal. Though, to be completely honest, ball jointed dolls aren't meant for children in the first place.
    Just my two cents! A wonderful 'ible.
    foobear
    foobear
    Thank you. Yes, if flexed too rapidly and repeatedly, the wire will break.
    I don't know about the ball jointed dolls you mention, I would not know how to fabricate that myself. Perhaps you will write an instructable about it?
    Hot Toys makes a line of very poseable action figures which are very nice, but also very expensive.
    urbanwoodswalker
    urbanwoodswalker
    Ball jointed dolls are VERY expensive. I just woke up, cannot think of the Asian company that is known for these (Sybarites, Super Dollfies etc...see below for links)....but they are exquisite. The web is full of images.
    I agree...the ball jointed ones Insomnia speaks of are not playthings for children. Even GI joe dolls / accessories were expensive back in the day...I remember my folks telling us that .
    I think these are wonderful for display scenes, dioramas, and photo shoots. If the bends are not extreme, and the wire is soft...the bends will last a long time.
    History:
    http://en.wikipedia.org/wiki/Ball-jointed_doll
    (this link has the names of the major current companies)
    http://www.flickr.com/groups/sybarites/pool/
    http://www.flickr.com/groups/bdjs/
    http://www.flickr.com/groups/balljointeddolls/
    http://www.google.com/images?um=1&hl=en&client=firefox&rls=com.yahoo:en-US:official&tbs=isch:1&&sa=X&ei=iIj_TPmLG9CNnQecvtGsBw&ved=0CDQQBSgA&q=super+dollfies&spell=1&biw=1057&bih=475
    Grafton
    Grafton
    Potential experiment:
    Assemble, but do not glue, the hacked doll. Put that heat-cure foam clay called 'Pluffy' over the wire joints. Dissemble. Bake the 'Pluffy'-covered wires to cure. Reassemble and glue.
    According to the manufacturer, thin pieces of baked 'Pluffy' are flexible and durable. If this is true to a good enough degree you'd have a doll with much nicer looking joints, and better durability overall because you'd glue the edges of the 'Pluffy' joint-cover to the edges of the cut limbs and have more glued surface area than just the ends of the wire, and more porous/rough surfaces for the glue to grip.
    foobear
    foobear
    This sounds interesting. I'll look around for pluffy. thanks
    Dream Dragon
    Dream Dragon
    Really interesting piece of work, doesn't the wire fatigue and break though?
    foobear
    foobear
    I expect it will. Mostly I'm just using it with the intention of posing the dolls for animation or other artworks. So far they haven't broken through yet. But I think if it were vigorously flexed, it would.
