Introduction: Home Remedy How to Get Rid Off Acne
This instructable is my way to get rid of mild acne on your face and I've found this method very affective and very easy to constantly implement.
Step 1: Boil Water
As the title suggest take any pan and fill it with water and put it on a stove on high heat while doing step two.
Step 2: Exfoliation
Using a wash cloth, usually the softer the better, roughly wash your face and use soap. When you are done rinse your skin.
Step 3: Steam
Go back to your pan on the stove which should be close to boiling. You don't need it boiling but you need steam. Put your face over the water and let the steam flow over your face. If the team is too hot try putting the pot on a non-active burner and wait about 10 sec. and try again if its still too hot wait 10 more sec., but heat should dissapate fairly fast. stand over the steam for about two min.
Step 4: Dry
Using towle dry you face. Dry by patting do not rub with the towle.
Step 5: Medication (optional)
Lastly you can apply any medicine you have if its prescription or over the counter just follow directions.
