How to Import Custom Ringtones.
Intro: How to Import Custom Ringtones.
Hi I'm going to show you how to import custom ringtones. All you need is iTunes, a ringtone editor app or something else. It's pretty simple but can get difficult. All the steps are in the pictures below
STEP 1: Edit Ringtone
Use the app (I'm using ringtone designer) to make the ringtone
STEP 2: Save It and Plug Phone in to Computer
Once you save it plug phone into a computer
STEP 3: Open ITunes
Once done with that open iTunes
STEP 4: Go to Apps and Scroll to the Bottem
Go to apps from the bar at the top and go all the way down to file sharing
STEP 5: Select the App and Hit the Saved File
I have the ringtone app so it shows that one look over in documents and hit the one you made I did am I wrong
STEP 6: Drag to Desktop
Drag it from iTunes on to your desktop it will be a .m4r iTunes file
STEP 7: Go to ITunes and Select Library
Go to iTunes again and go up to the library button at the top right hand corner
STEP 8: Select Tones
Go to the top left corner hit the arrow and select tones from the choices
STEP 9: Drag in Ringtone From Desktop
Go to your desktop and drag in your ringtone you made earlier to iTunes
STEP 10: Go to Iphone
Just go to the right hand corner and select iphone
STEP 11: Hit Tones
From the bar go up and hit the tones button
STEP 12: Hit the Sync Tones Button and Then the Ones You Whant to Use
Hit sync and select the ones you whant to use
STEP 13: Hit Apply
Go to the bottom and select apply (lol I said bottom :p )
STEP 14: Go to Sound Settings and Hit Ringtone
Go to settings sound ringtones
STEP 15: Go in and Select Your Ringtone!
Go select you ringtone and set it as default and there you go!
STEP 16: Troubleshooting
1. "Not seeing shared documents", sync your device with iTunes
2. not seeing Ringtones, make sure you clicked and followed every directions in this tutorial
