How to Learn Creative Composition
Intro: How to Learn Creative Composition
Creative composition: Interesting Photography works
STEP 1: 1.Clear Theme
Capture the things that touch your
When you're a beginner, the primary purpose that you pick up the camera may be familiar with the camera settings, and when the period of time, you are already familiar with your equipment, you need to consider the additional question becomes - - What is your creative source? The photographers with some experience will no longer glance the LCD screen after pressing the shutter to confirm whether the parameters are correct or not like beginners. Photography is raised as a medium to convey information at this time, they expose reality or explain their point of view hrough the lens. Potographing a properly exposed photograph at this time is no longer their pursuit, liberating the imagination and showing clear theme are the purposes of their works.
STEP 2: 2. Visual Ambiguity
Visual ambiguity
Visual ambiguity actually has conflict with the clear theme, photographing clear theme allows you the opportunity to convey your emotion to the viewer through photography, and visual ambiguity leaves space of imagination for the viewer. Visual ambiguity conveys ambiguous message to the viewer through some special elements in the photography works. The photography works which make people produce visual ambiguity often highlight the details of things while ignoring the overall outline.
STEP 3: 3. Abstract
Visual Effects
The focuses of abstract photographic works tend to stay in the subjects' visual attributes rather than their nature, beauty and details. Like abstract painters, what abstract photographers are more concerned about is not just the subjects’ overall visual effect, they use colors, lines, shapes and other visual languages to convey information in photographic works. Photographers have found a unique angle and way to look at the conventional things through abstract and create unique effects such as photo montage.
STEP 4: 4. Looming
Enlarge architectural details while ignore the overall deliberately
Common photography works usually put the focus on the integrity of the subject, the viewers who are accustomed to this kind of photography works prefer to enjoy the strong visual effects of the work without thinking, their eyes do not stay in the similar works. Those looming photography works can often seize the audiences' attention, because they only show some details but leave rich imagination for the viewers.
STEP 5: 5. Capture the Changes
Change
Capturing the change refers to using photography works to show the subject's size, color, brightness and other subtle details of changes. Showing the changes of the subject in photography works is easy to guide the viewer to relax and enter the situation depicted by the photos. Such as messy irregular hilly areas, surging seas, etc., are all good subjects for creation.
