How to Make a Hair Stick
588
Introduction: How to Make a Hair Stick
these r the list of items u need
1.piece of plastic wood about 6 inches
2.file set (6 items)
3. anti cutter
4.fine sand paper (1200 grade)
5. drill bit of 1/16 size
6. pen or pencile
Step 1: Now Mark the Wood With Ur Design by Pencile
draw ur desired design on the plastic wood piece and remember the length u wanna make it cause ur design should be according to that i am taking 5 inches for length.u can take as u like
Step 2: Now Cut It Slowly With Anti Cutter Carefully
now cut it slowly with ani cutter carefully. then it will look lyk this image
Step 3: Cutting Da Edges and Making It Even
cutting da edges and making it even with anti cutter .then it will look lyk these images
Step 4: Making Its Smooth
this is the step which have to do with patience and care
using da file make it smooth and give it shape as u desire. i wanted to make is rounded shaped so i used different types of file to smooth it and give it shape.now there are curves so i used different file for different curves, made my work easier and fine
Step 5: Now to Make It Fine
now use the sand paper (i used 1200 fine sand paper for it) to make it more fine and smooth.then it will look lyk these images.
Step 6: Make a Tiny Hole at the Top and Ornamentation
make a tiny hole at the top with the drill bit (1/16) with hand , it is plastic wood so bore it hand dont use drill machine or hand drill just use ur hand.u may skip this step cozz i made to use some string for little ornamentation
now u can either color it or keep it as it is . i used a glue called araldite and gave it a think coat for Lillie strength and glossy effect.
now i am using wooden beads for ornamentation u can add what ever u lyk.
Step 7: Final Outcome
well tried to show something hope it helps
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Remote Control Contest
    • Sculpt & Carve Challenge
    Wow it looks really nice, I bet the waves really help the hair stay up and the beads are so pretty!
