Introduction: How to Make a Mini Wooden Crossbow
hi, this is my first instructable, so if you notice some mistakes, please respond. In this instructable i will be showing you how to make a powerful, small wooden crossbow out of stuff that should not be too hard to find.
Step 1: You Will Need:
Step 2:
Take two of your skewers and cut off the sharp tips. Tape them together about 1 cm.(0,3 inches) from the ends. Now, tie your wire to one end, bend it and tie it to the other end.
Step 3: The Body
Hot glue your two pieces of wood together. Glue and tape your bow on the body.
Step 4: Arrow Suports
For this part you are going to bring up those last two skewers. That is just what you will need for this. Cut them down to about the same length as the body (little shorter). Try to glue them close to each other without touching.
Step 5: The Trigger
Pick up your wooden clothespin and drag the bottom off. We are only going to need the part with the steel thing on. Cut off as much as you can from both sides ( but no more than i did here) ( we are doing this so we can put on the trigger). Then make a groove 6,5cm(ca.2,5 inches) from the back end and ca. 0,5 cm deep ( 0,2inches). Clip on the clothespin.
Step 6: Arrow
Its your choice now, you can make your arrow out of almost anything. i made mine out of a skewer. You can use the rest of the arrow holder. Just put some masking tape on the back of the arrow and then cut to this > shape.
Step 7:
Now have fun and remember to be careful. NEVER point it at anything living!!!! This is extremely powerful! it is a fun toy to bring to work or school. You can even bring it in your pocket just put your T-shirt over. Also check out my other instructable on how to make an awesome catapult designed by Da Vinci!
