Introduction: How to Make an Air Gun
HOW TO MAKE AN AIR GUN IN 5 SIMPLE STEPS
MATERIALS:
1 BOTTLE
1 GAGE
1 LONG PIPE
1 HOSE GUN OR AIR LINE FITTING
1 COPPER PIPE
1 CONNECTOR (BOTTLE TO PIPE)
1 BIKE VALVE
Step 1: Makeing the Air Chamber
FIRST GET THE BOTTLE AND THE BIKE VALVE. DRILL A HOLE IN THEN BOTTLE BIG ENOUGH FOR THE BIKE VALVE TO FIT THROUGH THEN DROP THE BIKE VALVE IN THE BOTTLE THEN POKE IT THROUGH THE HOLE GLUE THE BIKE VALVE SO AIR CANT GET THROUGH OR YOU CAN USE PVC PIPE INSTEAD OF A BOTTLE.
Step 2: Putting the Gage On
DRILL A HOLE I THE SIDE OF THE BOTTLE AND THEN PUT A BIT OF GLUE AROUND THE EDGE THEN SCREW THE GAGE ON (THE GLUE IS TO GIVE THE GAGE MORE SUPPORT AND MAKE SURE THE AIR DOESNâT COME OUT)
Step 3: Connecting the Pipe to the Bottle
GLUE THE CONNECTOR IN THE END OF THE BOTTLE THEN PUT A BIT OF GLUE AROUND THE END OF THE CONNECTOR THEN PUT THE PIPE ON TO IT
Step 4: Connecting the Trigger to the Pipe
CONNECT THE END OF THE PIPE TO THE HOSE GUN OR AIR LINE CONNECTOR
Step 5: Connecting the Barrel to the Gun
CONNECT THE COPPER PIPE TO THE HOSE GUN OR AIR LINE CONNECTOR I USED A PIECE OF RUBBER PIPE TO CONNECT THE AIR LINE CONNECTOR TO THE COPPER PIPE BECAUSE IT WOULDN'T FIT STRAIT ON.
Step 6: How to Use It
PUMP THE BOTTLE UP AS MUCH AS YOU WANT USING THE BIKE VALVE AND A PUMP THEN PUT SOMETHING IN THE BARREL THEN PRESS THE TRIGGER
29 Comments
12 years ago on Introduction
Jeez, could your pictures be any blurrier?! And whats with the caps lock? please, try to be a little more informative, and not sound like your yelling all the instructions at everyone. I'm surprised this hasn't been confronted by the admins. I like your ible, it just needs alot more work before you publish.
neet im posting one soon
13 years ago on Introduction
Lol, dude, add a disclaimer and a warning. Just in case someone got one explode in his face and went to the hospital and point the finger at you (aka. you get sued).
16 years ago on Introduction
yep some pics below, first two are over-under combustion launchers, the 3rd is a pneumatic nail gun assult rifle, and the last one is a plinker you can hide in a pencil case and shoot a nail out of
Reply 15 years ago on Introduction
nice combustions heres one of mine it can launch 1/4 of a mile or moreair cannon
I don't have the patience to pump huge guns, I love small pneumatic guns, and large combustion guns
check out this baby I made a few months ago
http://s156.photobucket.com/albums/t31/frank26080115/air_gun/
Reply 13 years ago on Introduction
same
Reply 14 years ago on Introduction
can you tell me how you made all of them if you do can you make the instructions as simple as possible... ...i dont always follow things well
You should post Instructables for the first one
frank nice design in making a pumatic launcher in a while so will you ckech it out once in a while you look like a expert soo ..... check it out !'
the pics are a bit blurry..
TURN OFF THE CAP LOCKS LOL
yeah... LOL
Im getting a bit confused what do i ask for at the store when I said i needed something to act like a trigger but cut the air off untill i fire the guy thought I was crazy. Please help!!!
i got rid of it lol BUT i will try to make another but i have a flamethrower in the making for a ible
i have done a miniture Version off this but i Made it stronger using a technique bottle rockets use with Getting a larger bottle and Shrinking that down to the same size Making it thicker !
HOW DID U MAKE THE BOTTLE SMALLER?
You cut a slit down the middle Put it over the Other bottle and put a blow torcg (or lighter) near it so it melts it but not to a extent the plastic burns And spin it very slowly it will eventually melt
thanks why dont you post a instructable on the mini version
what sort of glue would i use?
