How to Make Beautiful Hooks From Twigs and Sugru:) (+ New Video)
Intro: How to Make Beautiful Hooks From Twigs and Sugru:) (+ New Video)
maybe I sound silly but I love twigs !!!!!!! :)
here is my idea for how to make awesome hooks with twigs and sugru
hope you like it !
This is our new sticky video to show how well sugru bonds to loads of different materials.
hope you like it !
STEP 1: Collect Twigs
go to your local woods, the end of your garden or if you live near the coast you could find some beautiful drift wood.
collect lots of twigs, big and small and take them home, you could be surprised with what you end up using.
STEP 2: Snap Twig to Size
snap your twigs to size, I like to snap my twigs because it leaves a lovely natural break.
Think about what you want to hang and what kind of hook would best suit that. Select the most suitable twigs from your collection and get snapping.
I would recommend not to snap too short to start with.
STEP 3: Chose Your Twig and Prepare the Surface
Offer your twig up to the wall as a quick test...
Why not experiment with the different twigs you have.
Once you are happy, make a note of where the sugru will be needed.
If the wall is dusty or dirty, give it a wash and let it dry.
STEP 4: Mix Sugru to Get the Colour You Want
You can mix sugru to get a nice earthy colour for your twig.
For a full range of colours that can be mixed I have added the sugru colour mixing chart here.
A nice earthy green is a mix of orange and green and an earthy brown uses orange and blue :)
For this I used a full sachet of orange and about two thirds of a sachet of green
Take a look at our colour mixing video here.
STEP 5: One Piece of Sugru Onto the Wall
break the sugru into two pieces, roughly one third and two thirds.
Press the smaller piece of sugru onto the wall creating a compact pyramid of sugru, be careful not to spread it out.
It is important that you press the sugru repeatedly onto the wall so that the sugru has the best possible grip. I pressed this at least 20 times until I was confident that it had a good grip.
STEP 6: The Other Piece of Sugru Onto the Twig
Apply the rest of the sugru to the twig.
roll the sugru into a saussage.
Wrap this around the twig at the point of contact with the wall.
press the sugru gently and repeatedly until you are happy with the shape.
STEP 7: Pop the Twig Onto the Wall
Press the sugru on the twig onto the sugru on the wall.
Press the two parts together gently but firmly.
Once the twig is fixed to the wall, you can blend the sugru until it looks the way you want it.
STEP 8: Enjoy Your Lovely New Hook :)
once the sugru has cured, my new hook is ready for a life of service :)
20 Comments
tarepanday 13 years ago
projectsugru 13 years ago
yes, there are. It does not bond well to polyethylene / polypropylene. Typically it will not bond to greasy plastics.
It bonds very well to batural materials; metal, wood, glass, ceramic, glass, leather and loads of plastics etc.
Usually good to test it out if you are not sure. Hope this helps. Are you thinking of using it for something specific ?
fanman7 12 years ago
projectsugru 12 years ago
However, as this is an engineering plastic, you can screw a small crew into it and then build the sugru around the screw :) It's a bit more complicated but will definitely work.
Would love to see an ible for that :)
no need for screws on the wood, it will bond brilliantly to that :)
i have thought of making a key holder with sugru on the wall, but i afraid i might take off the paint when i move away one day. btw, do you just use strong force to tear sugru away if you want to remove it one day? for example on an iphone or the wall, are there tips on removing it?
one more question, how does spray painting or painting in general work on sugru? im thinking of spray painting one of my projects that uses sugru with a silver chrome colour....
So on your wall it should be possible to remove it without damaging the paint. However, the paint is the weakest link there and will be the first to fail if you apply a lot of force / weight to the key holder. But as it is just a key holder, it should be totally fine.
We haven't painted sugru ourselves but we have heard that it tends to flake off.
Hope this helps.
James
eman_p 13 years ago
sugrujane 13 years ago
eman_p 13 years ago
blacksmith_tb 13 years ago
amagriva 13 years ago
mdeblasi1 13 years ago
Kryptonite 13 years ago
kemper 13 years ago
Electrocutables 13 years ago
Whales 13 years ago
