How to Make Bo Shuriken
Intro: How to Make Bo Shuriken
ive been gone for a while and i took my insrtuctable with me
STEP 1: Materials
you will need
pole barn nails
string
scissors
safety gogles (cause you dont wanna be like hitler)
a benche grinder
pole barn nails
string
scissors
a benche grinder
STEP 2: Make the Nails Shuriken Shaped
grind off the head of the nail and sharten the tip the tip must be very slender
STEP 3: Quench
remember to quench the nails in water every now and then to avoid damadge
STEP 4: When You Are Done Grinding
it should look like this
STEP 5: Make It Look Authentic
am an asian person so i take some pride (if any)in my shuriken
take your string and cut peices of equal lenghth i used 2 colors for more vivid patterns
STEP 6: Start Wraping
put your newly cut string around the back of the shuriken and start to wrap it tight then knot it off when you are done
STEP 7: And Your Finished
you hold them as shown making a groove with your fingers
for throwing information go to secretsoftheshuriken.com
56 Comments
ghaines1 7 years ago
Do you find the weight to be heavy enough? I don't know what a pole barn nail weighs. Most of the bo shuriken I've used from Japan are surprisingly heavier than you might imagine. Of course, those might have been for dealing with different armor / clothing / distances than you may need for these.
David Ahlstrom 12 years ago
MAVREV13 14 years ago
jordan c 12 years ago
divinehex 13 years ago
An Villain 13 years ago
cantbesaved 14 years ago
NONE OF IT
1.5) the 8 sided shurikens real
2)I HIGHLY doubt it. if you were even accurate enough, the shuriken would cut the BB/pellet in half
littlemog92 14 years ago
Also it depends on the mass of the object being stopped compared to the object doing the stopping.
When a 55 gram piece of flying metal lets say it has momentum of uhh....well 50 joules(that sounds right). makes contact with a .25 gram bb uhhh.. 1 joule at the most, going the opposite direction.
Guess which one wins.
In newtons third law it says, "For every action there is an equal and opposite reaction".
that pretty much explains it. Sure the bb will have some effect on the heavy peice of metal with momentum but not much.
The one fact I know is that you cant throw a shuriken that is longer than your arm.
my friend is real dumb i had a feeling about that and thank and yes when i think of him Speshal is 1 word that pops into my head and not the Good term.
heavy.metal.nguyen 15 years ago
naruto the ninja13 13 years ago
J@50n 14 years ago
this mans idea was really good try something like this
strmrnnr 15 years ago
josefu0 13 years ago
