How to Make the Best Smoke Bomb in the World for Insanly Cheep.
Intro: How to Make the Best Smoke Bomb in the World for Insanly Cheep.
This smoke bomb will create white smoke enough to fill a two car garadge. With out seening a single flame.
STEP 1: Drawing.
If it helps you, you can draw a picture as you read to make it easier to visualize the instructable. Just to let you know this is my first instructble so my instructions my be a little hard to understand. Sory that there is no pictures I didn't know how to do that. Please give me some feed back.
STEP 2: Materials You Need.
You will need a variety of things.
.You will need a hammer. To fold the coners in and the remaing tab down.
.You will need a thick nail./ To poke holes in the can.
.You will need a pair of sicors./ To cut the ping pong balls and to cut the beer can.
.You will need a bottle rock./ For the fuse.
.You will need a razer blade./ To dismanel the bottle rocket.
STEP 3: Step One
Take a large beer can and cut off about 3/4 inches to 1 inch off the top. Make sure to first empty it into the sink. Take a paper towl and dry it out.
STEP 4: Step 2
Cut up about three ping bong balls with the sicors and put the pieces into the bottem of the beer can. Take about 3 pices of toilet paper and rip it up puting each piece on top of the first layer of ping pong balls. Push down on the toilet paper so it is all the way at the bottom but no ping pong balls can be seen.
STEP 5: Step 3
Cut up 4 ping pong balls and put the pieces in the can.
STEP 6: Step4
Put five sheets of toilet paper ontop of the second layer of ping pong ball pieces. Rip up some very thin cardboard pieces about three of them, 1-2 centimters long, almost covering all of the second layer of toilet paper. Pushdown on the toilet paper so that every thing below it gets packed down. YOU should have atleast 3 inches of room left.
STEP 7: Step 5
Now you must cut up 6 ping pong balls and put them in the can. Then take 7-8 sheets of toilet paper and put it on top. Then push down on the third layer of toilet paper. You should have about an inch or two of room left. Sprinkle very slowly any liquid flamible chemicle ontop. I used a remover called Gunk Off. But you can use a small amount of lighter fluid. What ever you use dont soke the toilet paper. Only sprinkle for about 3-5 seconds.
STEP 8: Step 6
Fold over the remaning top of the tin can as far as it will go. Then fold the conrners in. To fold it over use the hammer, hammering it down.
STEP 9: Step 7
Take a thick nail and nail about 5-7 holes in the front and back for oxigination to create smoke. Then poke three holes in the very bottom side by side. This is all done by using the hammer and nail. The most important part is two make a hole twice as big next to one of the folded in coners.
STEP 10: Step 8
Dismantel a bottle rocket and take out the fuse. Take the fuse and shuv most of it into the larger hole by one of the folds on the coner. Leaving about half an inch remaing sticking out.
STEP 11: Ssssszzzzzzz
Light the fuse and back up but you might want to were glasses or gogals, any eye protection will do because the polyurathane in the ping pong balls once burnned will hurt your eyes.
