Introduction: How to Make Your Xbox Controller Blink With Some Leds,but It Won't Shake Anymore
About: i try to fix things
YOUR REMOTE WILL BLINK BUT IT WON'T VIBRATE ANYMORE BECAUSE IN THIS PROJECT YOU HAVE TO TAKE OUT THE MOTOR.
Step 1: MATERIALS FOR THIS PROJECT
1.XBOX CONTROLLER
2.LEDS
3.SCREW DRIVER
4.SOLDERING IRON
5.SOLDER
Step 2: OPENING YOUR CONTROLLER
TAKE OOF ALL THE SCREW BUT BE CAREFUL NOT TO STRIP THEM.
THEN DESOLDER THE VIBRATING MOTORS BECAUSE THATS WHERE THE LEDS ARE GOING TO BE CONNECTED TO .THE RED WIRE OF THE MOTOR IS THE POSITIVE SO MAKE SURE TO REMEMBER WHERE THE POSOTIVE IS .THE LONG STICK ON THE LED IS THE POSITIVE SO MAKE SURE TO CONNECTED POSITIVE TO POSITIVE AND NEGATIVE TO NEGATIVE.YOU COULD ONLY USE TWO LEDS FOR EVERY POWER SOURCE.ANY COLOR OF LEDS.
Step 3: TIME TO PICK a PLACE FOR THE LEDS
YOU COULD PUT A LED ANYWHERE YOU WANT IT, BUT MAKE SURE THE CONTROLLER COVER CLOSES .I DRILLED A HOLE THE SIZE OF THE LED AND IT FITS PERFECTLY.YOU CAN USED A SMALL DRILL THAT MAKES A SMALL HOLE THEN USE A REGULAR SIZE SCREWDRIVER AND SCREW IT IN THE HOLE AND THAT WILL MAKE THE HOLE BIGGER, AND ITS THE SAME SIZE AS A LED.IF YOU DON'T HAVE A DRILL YOU CAN HEAT UP A SCREWDRIVER THEN STICK ANYWEHRE YOU WANT YOUR LEDS TO BE AND THE SCREWDRIVER WILL MELT RIGHT IN AND MAKE A HOLE.
Step 4: PUTTING EVERYTHING TOGETHER
AFTER YOU HAVE MADE THE HOLES CONNECT THE LEDS TOGETHER ANDCONNECT THE LEDS TO THE CHIP AND MAKE SURE THEY WORK BEFORE YOU CLOSE THE COVER.DON'T USE TO MUCH WIRES TO CONNECT THE LEDS BECAUSE THEN THE COVERS MIGHT NOT CLOSE.AFTER YOU CONNECT THEM PUT THE LEDS IN THE HOLES YOU DRILLED .THEN CLOSE THE CONTROLLER COVERS AND MAKE SURE THE WIRES ARE NOT IN THE WAY OF THE BUTTONS OF THE CONTROLLER .IF THERE NOT THEN MAKE SURE THE WIRES ARE NOT STICKING OUT .AFTER YOU ARE ALL DONE SHOW IT OFF TO YOUR FRIENDS.
