How to Wire-up a Light Bulb-socket
Introduction: How to Wire-up a Light Bulb-socket
tired of hiring electritions to do all of your simple electric work? thats all about to change!
Step 1: Items
you need:
a male electric outlet cord, a new light bulb-socket, and a flat head screwdriver.
Step 2: The First Thing You Need to Do Is,
pry the end cap off with a flat-head screwdriver: put aside.
Step 3: Slide It Out
slide out the socket with your fingers: put aside the socket & metal casing.
Step 4: Striping the Wires
strip about 4/5in. of insulation off of the wire.
Step 5: Sliding the Wires Through
slid the wires through the end cap.
Step 6: Curving the Wires
curve the wires in the clockwise direction.
Step 7: Attachment
attach the wires to the screws: screw on tightly
Step 8: Re-attachment
push metal casing back on socket.
Step 9: Snapping On
snap on the metal end cap.
Step 10: Finished
the finished socket. any better than the last one?
Be the First to Share
    • Clocks Contest
      Clocks Contest
    • Baking Contest
      Baking Contest
    • Block Code Contest
      Block Code Contest
    20 Comments
    julieneary
    julieneary
    Question 4 years ago
    how do you wire a chain into it
    seapunkies
    seapunkies
    6 years ago
    (actually, I was just making tiny lamps out of night lights you buy at the dollar store, I probably won't abandon that altogether.)
    seapunkies
    seapunkies
    6 years ago
    Oh wow! You have just improved my life 100% at least. I love to come up with creative and really cool Ideas for lamps, but my husband NEVER had time to wire them or show me how! You are fantastic! So if you don't have a cord laying around, I guess you could just cut the cord off the toaster. (after you unplug it) Toast is just burnt bread. I see potential lamps plugged in all over the house! haha jk
    GilbertF2
    GilbertF2
    6 years ago
    Hey so I have that exact same bulb socket and it comes pre-wired. What I want to know is if I attach a plug to the end of the cord and plugged it straight into the wall... What then? Do I need a special bulb or whatever or do I need to control how much power reaches my bulb? I'm making a chandelier for an art project and I know basically nada about electricity.
    mkambas
    mkambas
    9 years ago on Step 10
    wow, i take my hat off to you, tecno geek. a son of an electrician myself, and i can't even screw on a lightbulb right! your step by step guide is a model of instruction! wish i took electricity 101 w/you as my instructor. boy, you make it so easy! thx much. gonna check your other posts next...
    SwagLord69
    SwagLord69
    Reply 7 years ago
    sweg
    Cyncha227
    Cyncha227
    Thanks, you present this as straight forward as I imagined it was. I just needed to see it for myself, not fast, not with any mystique, but just as I would see it if I were to do this all the time. Thank you!
    nplant
    nplant
    11 years ago on Step 7
    It absolutely does. There's a hot wire, and a neutral wire. The hot wire goes to the hot terminal, the neutral goes to neutral.
    http://www.familyhandyman.com/DIY-Projects/Electrical/Electrical-Repair/how-to-wire-a-light-socket
    jatb28
    jatb28
    does it matter which wire I attach to each screw?
    timglum
    timglum
    12 years ago on Introduction
    Does the cord have a ribbed side and does that need to be matched to the right screw or is that only for lamp sockets / holders going into ceiling fixtures etc?
    jroberts20
    jroberts20
    Reply 11 years ago on Introduction
    If you're just wiring a single socket, say for a lamp the right wire to the right terminal (screw) is not critical, however for safety it's a good idea to use lamp wire instead of extension cord, and connect the ribbed (neutral) wire to the neutral terminal, and the smooth (hot) wire to the hot terminal. Also, I noticed this tutorial did not mention the need to put an underwriters knot in the socket casing which is another safety measure.
    If you are wiring up more that one socket to a single power cord you definitely need the right wire to terminal configuration.
    I'm not an electrician, this is basic DIYer stuff.
    Da_Fudge
    Da_Fudge
    14 years ago on Introduction
    Huge Improvement on your other instructables!!!!! Good pictures too!
    Saint
    Saint
    Sweet looking socket you got there... looks almost a bit steampunk, very nice. Too bad they only sell ugly cheap plastic ones here.
    GorillazMiko
    GorillazMiko
    GREAT job! Very well done, and agreeing with everybody else... much better. :D
    Kiteman
    Kiteman
    Much better.
    Still one minor point - the socket is a female connector.
    PocketSized
    PocketSized
    Well done on re-making your Instructable. You've taken on board everything people had said in the original one, which is excellent. Your Instructable is much better. Congrats
