"Mine" Your Own Ferromagnetic Metal (slivers)...
Introduction: "Mine" Your Own Ferromagnetic Metal (slivers)...
Tired of paying for that ferrous metal scraps that you mostly use for entertainment purposes among other things. Well here's how you can make your own ferrous metal scraps that you can use for such things as: ferrofluid, science classes/entertainment (put the magnet under the paper to teach about magnetism), etc.
Materials you'll need are:
1. Big, strong magnet (or several small ones. I used my modified 6x8 speaker magnet)
2. Little, strong magnet (I used one of my magnetic darts)
3. Hoe (optional)
4. Plastic sandwich bags
5. Mortar and pestle
6. Small container and a lid
7. Large container
Step 1: Finding a Good Fishing Hole....and Cast Out.
One of the best areas to find a good source of ferrous metals is the ground....No seriously, where do you think metal comes from? Don't answer that...
A mixture of gravel and sand is usually one of the better spots for this (beaches are also great, but I'm not there).
1. Use the hoe to break up the surface of the ground into a small pile of dirt.
2. Put your large magnet into one of the sandwich bags and hold onto it with your hand. Keep the large container close by.
3. Now start to sweep the ground as shown in the last picture. You can push the pile of dirt out, to get at the metals underneath. Move your hand with the magnet around as if you were washing the ground....
Step 2: Reel 'er In....Grind 'er Up.
1. When you look at the bottom of your magnet, you should see pebbles, sand, and slivers of metal sticking to the bottom side. Now put your magnet over the large container and peel the bag away from the magnet, starting from the top (Just to clarify things....keep the magnet inside the bag and use your other hand to seperate the side of the bag with metal on it away from the magnet so that the metal will fall into your container). Now repeat until you think you have enough.
2. Now get your mortar and pestle out. Pour a small amount of your mixture into it. Grind it until you get a fine powder. This will also allow the pebbles with the ferrous metals inside to release them.
Step 3: Finish It All Up...
1. Now pour a little bit of the powder into the lid. Shake the lid to spread the powder out thin.
2. Take the small magnet and place it inside another sandwich bag (at the tip). Now scan over the powdered mix, but don't get too close or you'll end up with some paramagnetic materials which are only weakly attracted to magnets (we don't want the weak stuff). So stay around .25"-.5" above the powder. This will allow the magnet to attract the ferromagnetic materials, while keeping the other away.
3. After you've scanned enough so that the tip is covered, place the magnet over the small container and pinch the tip of the bag (along with the metals) and pull the magnet away from the corner. The metal will now drop into the container (as long as you remember to let go).
Once you're done and there's nothing left to attract (except the paramagnetic materials), throw away the "dirt" and start the process again.
All the ferrous metal in the picture below was gathered and processed within an hour. Slow going I know, but saves a bundle. I'm actually in the process of designing a contraption to make this process faster and easier. But until then....Have fun.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    39 Discussions
    thoraxe
    thoraxe
    12 years ago on Introduction
    Cool! i'm gonna make a charcoal furnace, and put this inside and make my own iron!
    -Aj-
    -Aj-
    Reply 12 years ago on Introduction
    im going to make a charcoal furnace (if you can call it that) and make charcoal for my blackpowder mill! its called, get pinecones, an empty CLEAN pain tin (dont want vapors of death coming out) punch afew holes in the lid, chuck in some pine cones put the lid back on. (this is a metal paint tin, ofcourse) and put it on a gas burner or even on a fire. you will see gas/ steam stuff come out of the holes, after awhile the steam stuff will stop, this means the pine cones are now completely dehydrated. take it off the heat, wait for it to cool would be good, then open. you will have much shrunken pine cones that are black. this is very good charcoal. the best pine cones to use are ones that have opened but are still that nice reddy brown colour.
    thoraxe
    thoraxe
    or, and harder but more efficient way is on this site:
    http://64.176.180.203/charcoalretort.htm
    but i blacksmith with it, so i need much larger amounts than you will, so your method if perfect 4 u.
    oh, and did u know that those vapors coming from the can are flammable?
    strmrnnr
    strmrnnr
    Hey Dude, Happy Holidays.
    Just to point out your link is broken. I don't know if this new one compares to the broken link, but it reads good.
    http://www.puffergas.com/historic/rules/rules.html
    Cheers
    strmrnnr
    strmrnnr
    Yes this is the guy I learnt that process from also for small scale charcoal.
    -Aj-
    -Aj-
    thanks for the link.
    yeah id expect that they gases would be flammable, although i thought the majority was water vapor, might depend on the wood. like eucalyptus as opposed to pine.
    i like the idea about re directing the vapors back and using them to do the cooking though, good idea that one.
    yeah i would use 200L or 44gal drum (same thing) but i dont have one that i can use. all have/ had elf fuel in them. explosion if not washed out properly = do not want.
    history323
    history323
    10 years ago on Step 2
    instead of a mortar and pestle coulld you use a ball mill?
    Jaycub
    Jaycub
    It's probably overkill but it should work the same. You might also try using a glass bottle or something for a rolling pin to smash it up, that's what i have done in the past to make realy fine and well mixed gunpowder (i used thick cardboard tubes though because glass is good at making static).
    history323
    history323
    Thanks!
     by the way cool 'ible
      liked it alot!!!
    AlexTheGreat
    AlexTheGreat
    13 years ago
    I usually just skim the floor with a 1in by 1/2 in neodnium magnet after I grind metal. then i add it to this (it winds around the pole)
    FrenchCrawler
    FrenchCrawler
    Reply 13 years ago
    I also collect the "trimmings" of metal that I happen to grind, but that way takes a while (at least for me, cause I don't really have anything to grind). Nice picture though. The way I've just shown though, doesn't require any metal to be ground down (except by mortar and pestle) and parents can keep their kids busy. Tell them that evey pound of ferrous metal they bring to them, they'll give them like a dollar or something (kind of like on Spanglish). Now only if I had some kids.
    benthekahn
    benthekahn
    11 years ago on Introduction
    In ocean beach in san francisco, this stuff is everywhere. My dad and I harvested two five gallon buckets of it in about an hour.
    dakellymon
    dakellymon
    Here are some photos of some magnetite, I collected over 20 pounds of this on a sandy beach along Lake Michegan. It is actually bunch of tiny magnets. You can see how they line up and attach to each other in the picture with the dime. It is very magnetic and for some reason, whatever other metal it is mixed with keeps it from oxidising. 10 lbs of it fits into about 1/4 high in a one gallon milk jug.
    Andrew546
    Andrew546
    13 years ago
    That's my size 12 shoe next to it for reference. That took me all of 2 minutes to collect. Thats a 1 gallon zip loc by the way.
