$3 Computer CPU Intake Fan Duct
36,726
71
18
About: I love to tinker with just about anything but some favorites are woodworking and other crafty things. I also enjoy repurposing otherwise useless things like old electronics and old tools and trying to see w...
Having a intake duct straight from the side of your computer case into the CPU fan can give you much better cooling than any other (air) cooling option. Instead of using air taken in from a front port, which has time to warm up from other components, the duct sucks in fresh air from the outside environment. Having an opening in the case in line with the CPU fan helps, but the air from this method is at best a mixture of some fresh air and some already from the case. There are some commercial solutions that aren't too expensive (usually $10-$20), but what I've made is definitely the right price - only $3.
Having used a collapsible fan duct for a few months, I finally decided that it was too much of a pain in the neck. First I had to modify it out of the box to fit on the fan for my CPU heatsink, then I had to duct tape it in place, and it would sometimes grind against the fan when it ran - it was a pain. I took it out and finally built something I'd been knocking around my head for a while.
This project is designed to fit an 80mm side vent, which seems to be standard on most mid-range cases nowadays. It will work with larger (or smaller) sided vents, but obviously you'll have to modify your materials, calculations, and assembly for that.
Step 1: Materials and Tools
Just a friendly reminder: Always know the proper use of any of your equipment - read any manuals and take all safety precautions. Safety glasses are recommended in just about any endeavor including tools, so if you think you need them, WEAR THEM. I am not responsible if you hurt yourself attempting this mod and I hope you don't. I managed to give myself a nice burn with my soldering iron doing another mod not long ago, which just goes to show you what can happen if you're not careful.
I used the following tools and materials in this build (there are other ways to do this, but this is what I had available to me):
Tools:
  • tape measure
  • calculator with trig functions
  • Miter saw (can be replaced by a regular hand saw)
  • Drill
  • 5/32" drill bit
  • 3" Hole saw (can be replaced with a scroll saw or a square saw)
  • drill press (makes using the hole saw easier)
  • calipers (not necessary, but helps)
Materials:
  • computer case with side intake vent close to CPU fan (if you're handy enough you can make yourself a vent)
  • 80mm by 80mm (3.15" x 3.15") piece of 1/4" plywood
  • 5" piece of 3" PVC piping
  • 4 regular case fan screws (or just two if that's all you can scrounge)
  • cyanoacrylate (superglue)
I say that this project only costs $3 because that's about what it cost me. All I had to buy was the PVC and the plywood. The PVC I had cut at my local hardware store (most, if not all, will cut to length for you) and the plywood was from a much larger sheet I used in a different project. Everything else I had on hand, so your costs may vary a bit. (Especially if you have to buy any of those tools ;-)
Step 2: Measurements
If you're lucky, your side intake vent lines up exactly with your CPU fan. If that's the case, you can skip the majority of the steps below. However, if you're unlucky like me, you'll have to put that trigonometry you learned in high school to the test (who would have thought you'd use that again?).
Begin by measuring the distance from the top of the case to the top part of the vent hole (measuring to the screw hole is good). Do the same for the side and write these measurements down. My original prototype was for example 4-5/8" from the top and 3-1/2" from the side.
Now remove the case door and measure the position of the CPU fan. Use the same method as above, except you'll have to eyeball it a little. It doesn't need to be incredibly accurate, just within an eighth of an inch or so. Mine were 5-7/8" (top) and 3-7/8" (side).
After this, determine how deep into your case the CPU fan rests. If you have a calipers, you can span a straightedge across the case opening and use the depth gauge to find it. If not, using the measuring tape and the straightedge works fine too. Mine was 3-1/2" deep.
Step 3: Calculations
Enter the mighty trigonometry functions.
First we need to figure out the displacement of the CPU fan when looking at it from above. In my example, the fan was 1-1/4" lower and 3/8" to the right of the vent hole. Plug this into the Pythagorean formula to get a displacement of 1.305" (about 1-5/16").
The number we just found is crucial for the next step. We need to figure out how long to cut the PVC and at what angle. We know the CPU fan sits 3-1/2" into the case, but we can subtract 1/4" because of the plywood piece that mounts the PVC. That leaves us with 3-1/4" deep and skewed 1-5/16" laterally. The Pythagorean formula gives us a total length of 3-1/2" for the PVC.
The angle can be figured out using tangent. With the opposite and adjacent sides known, one can easily figure out the angle theta in the third diagram. However, the saw must be set to cut at an angle of 22 degrees, not the 68 we found (90 - 68 = 22).
Step 4: Cut the Mounting Plate
If you haven't already, cut your 1/4" plywood into a 80mm by 80mm section (that's a little more than 3-1/8" on a side). Now you can use your case panel to place the screw holes. Simply put the mounting plate on a flat surface (that you don't mind getting drilled into) and put the panel on top of it, lining up the mounting plate with the vent opening. Hold it down tight to keep it from moving and use the drill and 5/32" bit to drill the screw holes.
After this it is time to cut the hole for the air to flow through. It just so happens that the hole for the fan in a standard 80mm fan is exactly 3" diameter, so a 3" hole sawing bit is just the thing. It's easiest if you mount the bit on a drill press and clamp the mounting plate to the bench. Or, if you can't find your hole saw like me, use a scroll saw to cut the hole.
Step 5: Cut the PVC
Now the tricky cutting. PVC, being round, will be somewhat problematic to keep steady while using the miter saw. The best idea is to take a piece of sacrificial lumber about 2" high and use that behind the PVC to keep it flush to the guide. Set your saw to the right angle (22 degrees in my case) and cut the first end.
Alas, here's the tricky part. You not only have to keep the PVC from rolling (and thus messing up your angles), but you also have to get it right length. I measured straight down the length of the PVC 3-1/2" and lined up the blade before I cut. It never hurts to double check the measurements before you cut. But if you do screw up, at least the PVC was (hopefully) not even $2 for the 5" length.
Step 6: Dry Fit
Now you have the two pieces cut and it's time to get them lined up correctly. There is no real *easy* way to do this. What I did is temporarily mount the plate on the case panel and then get the PVC situated right. Just place the PVC on top of the CPU fan, close the panel, and use a skinny screwdriver or something to get it positioned right.
Once you're sure the PVC is right, carefully remove the panel (as not to move the PVC) and take the mounting plate off. Now place the plate on top of the PVC and eyeball it square. Carefully replace the case panel and get the mounting plate as close as you can. Remove the panel carefully again once you're satisfied.
With the plywood still on the PVC, take a permanent marker and make some registration marks on the piece. You'll need these to line it up again after gluing.
Step 7: Assembly & Mounting
With the permanent marker marks on, it's time to get your favorite superglue out and put it together. Put a line of glue around the rim of the PVC where it contacts the plywood and press the two together. Hold it for about 30 seconds and it'll be bonded. If you want, add some more glue to seal up anywhere on the seam where air might leak.
Give the glue some time to cure (30 minutes should be plenty, just to be safe). You're now ready to put it on the case. When screwing the fan screws into the plywood, you just want to get them snug; don't overtighten the screws or you'll strip the plywood and lose all the grip from the screws.
Put the panel back on and fire the computer up. Put your hand to the vent hole and you should feel a good air flow into the case. Enjoy a better cooled CPU. Next step (when we all get the money for it) is water cooling :-)
    • Weaving Challenge
      Weaving Challenge
    • Epilog X Contest
      Epilog X Contest
    • Paper Contest
      Paper Contest
    18 Discussions
    pvalencia
    4 years ago
    does it have to be slanted? why not straight
    basejn
    8 years ago on Introduction
    I made this for my CPU before i read this. Te effect was awesome. The cpu was overclocked and it still maintaining tempriture below 40 C. About the dust ... it always intakes dust so frequently cleaning is important even without this .
    mays
    9 years ago on Introduction
    wonderfull instructable i liked this fan duct technology i must admitt that you are the only one gave me most advantages to my laptop since i recently joined you
    baneat
    10 years ago on Introduction
    my fan is JUST out of line with my CPU.. >:(
    ReCreate
    I remember somewhere i was that they put a tube over the processor and a supercooled liquid(not sure what it was though) and overclocked it to 5000mhz !
    djr6789
    ive benn needing this beacause my server heats up
    Yerboogieman
    kool, i bought three light up fans for $3.99 each at $2.55 shipping, for all of them
    A chrome version and a clear version would be great for gamers aswell, also I noticed my miter saw has a dent in it running along (like a little guide or something) perfect for keeping round stuff straight 'n true. I didn't make this for the computer but the ideas came in handy for another item. hence the metal one, I needed a similar item for the forklift air intake because all of were nicking our arms on the fan blades while spraying ether in to the intake and cranking the starter. Extend the intake with this. Also thanks to this there's no longer a stupid rubber intake thankyou very much for reminding me of my miter saw and pipes also the trigonometry was there already...
    Toulouse
    11 years ago on Introduction
    could you get some of those pre-shaped galvanized air conditioning and vent shapes (made out of thin metal) from lowe's/home depot and do this too? i think one of those would cost about the same and do the same thing
    frazeegToulouse
    Reply 11 years ago on Introduction
    Sure. I just find working with those more annoying and troublesome. Metal ducting is a pain ;-)
    LasVegas
    Great Instructable! I would have liked to see more pictures showing detail of how the duct fit inside and comparative results from before and after the installation.
    frazeegLasVegas
    I'll probably take some pictures next time I open the case. As it is it's just a pain to go under and unplug everything and open it all up, but I'll keep that in mind. There wasn't really any way to compare the before and after because I was already using a duct before I made this. I know that I got better cooling when I installed the original duct (and my CPU fan had to work less, gotta love AMD's Cool n' Quiet!). All I know is that this is much less hassle than the duct I had before and that's a good result for me :-)
