[A Cheaper Way To] Play Videos From Your Ipod on the BIG[er] SCREEN!!!
12,782
18
60
Introduction: [A Cheaper Way To] Play Videos From Your Ipod on the BIG[er] SCREEN!!!
About: Cool, another box!
After I saw the sat instructable that basically told you to buy some stuff, I had to share this with the world, it uses a 3.5mm AV jack (standard if you own a Digital Video camera or DV camera) with a couple of the plugs reversed.
Materials::::
:: An iPod Video
:: An AV-RCA cable with a 3.5mm head
:: A TV
:: Half a Brain
Step 1: Enable TV Output
Under the TV output settings, just make sure it says "Ask" Instead of "Off"
So when you select a video, the screen in the second picture will pop up.
Step 2: Get the RCA Cable
Got it ?
good!
Step 3: Plug It In, Plug It In!
Now comes the tricky part, you have to plug the headphone jack end ALL THE WAY IN to your ipod.
The even trickier part is actually plugging in the RCA cables, just follow the diagram on picture 2,
The Red cable goes in the Yellow hole,
The white cable goes in the Red hole
The Yellow Cable goes in the White hole
Easy Huh?
Step 4: All Done,
Now go to the movies option in the main menu, find a movie that you want to watch, and select TV ON from the little menu we talked about earlier.
Step 5: DONE!!!!
Now you can finally enjoy your little movies on the big(ger) screen!
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    60 Discussions
    Jo-dan
    Jo-dan
    10 years ago on Step 2
    where can you get one of these cables?
    Robot Lover
    Robot Lover
    10 years ago on Introduction
    they are all in different holes... do you know something that i don't?!
    Diabloscope
    Diabloscope
    10 years ago on Step 3
    Go to a car stereoshop,  they have a universal adapter ,for cars & CAN BE USED IN YOUR HOME , using the main connector on the bottom  ,   , it has  two wires for 12v+  connection  for Charging ,   has resistor built in .  if you are creative and  have a 12volt power adapter  ,you  dont have to worry about battery running Down !!
    homemovies64
    homemovies64
     my 5th gen white 60gb ipod video wont work with this connection! Help please
    tyeo098
    tyeo098
    Reply 10 years ago on Step 3
    Make sure you have the connections right. The colors are mixed up.
    miqt
    miqt
    11 years ago on Introduction
    ...what firmware do you have to have on your ipod video, 5 or 5.5??? because i don't see any options of "tv" or anything like that.....i have audio, but not video...any help? 5th generation video ipod should work, right?
    tyeo098
    tyeo098
    Reply 11 years ago on Introduction
    Dont know, dont have a zune. Build it and tell us!
    kiranshila
    kiranshila
    For any of you who are wondering, the new iPod Nano Chromatic, iPhone, or iPod Touch 1st or 2nd gen have a cable with a ID chip in them. This hack works only for the older models.
    schoonovermr
    schoonovermr
    I got the sound on the tv, but not anything else. I have an ipod touch by the way.
    Sigsaucer647
    Sigsaucer647
    someone needs to make one for the newer ipods that use the dock connector
    z50j
    z50j
    does this work with the 2nd gen ipod touch?
    Emankcin
    Emankcin
    This doesn't work with the 3rd gen Nano. After I hook stuff up, and select the movie, and get to the step where it asks if I want to enable TV, and I select yes, it says to connect the TV out cable. I tried to trick the system by connecting the firewire connector, but it didn't buy it.
    tyeo098
    tyeo098
    That's because the new ipods use the dock connector and there's no HW for the headphone jack hack.
    vatkin
    vatkin
    12 years ago on Introduction
    im almost sure this doesn't work with the ipod classic (6 gen ipods) and probably also the 3rd gen nanos
    gizmo_ult
    gizmo_ult
    Reply 12 years ago on Introduction
    it does just on your ipod it says video then click and go to settings that easy
    craigdiesel666
    craigdiesel666
    I can confirm this. I have the 80 gig Classic, and it needs the cable w/ a dock connector to send video out.
    carlos66ba
    carlos66ba
    13 years ago on Introduction
    OK, OK, lets stop this! We've taken over the thread for things that are really uncorrelated to it. Let's be friends :-) (should we delete all of this thread, since it is useless for the discussion at hand?)
