[Collegiate Meals] How to Make Sauerkraut
16,779
51
28
Introduction: [Collegiate Meals] How to Make Sauerkraut
About: Engineer making renewable energy products for African entrepreneurs.
Did you know that making sour kraut during world war II was considered patriotic in the United States? Because a great deal of our food was going to feed the war machine, preserving cheaply/easily home grown cabbage with salt was just one little extra boost. And because you don't need a heat source, you can do all of this in your dorm room!
"I Can, because I Can"
In this recipe I'm using primarily red cabbage and am adding 1 carrot, finely diced.
Teacher Notes
Step 1: Holy Salt Batman!
Here's what you need
Salt
Cabbage
A food safe Bucket
A Plate
Something weighty/easily cleaned (2L bottles work great when filled with water).
For every 5 pounds of cabbage - you'll need about 2.5-3 Tablespoons of salt.
Your plate should fit snugly inside your bucket
Step 2: Chop
Finely Chop your cabbage
Step 3: Bucket Time
Sterilize your bucket by washing with hot water and bleach - be sure to rinse away any residue bleach. Wash your hands/arms.
Start by sprinkling some salt in the bottom of the bucket.
Next add a layer of cabbage.
Sprinkle more salt
Repeat until you've all all of your cabbage.
Mix cabbage and salt together well.
Step 4: Pack Cabbage
Start pushing your cabbage down to the bottom of your bucket. Packing tightly. Some punching works well too. The idea to to pack the cabbage as tightly and as even as possible so that the water level stays above the level of the cabbage.
Place your cleaned plate on top off your cabbage - then place your cleaned water bottles on top of the plate. I'm using a pot full of bricks as my weight as there's no 2L soda bottles to be had for me (I'm back to my limited soda drinking ways).
Finally, over the top of the bucket with a towel (to prevent bugs/dust) and wrap a bit of cord around the outside lip (to keep bugs from crawling under).
Step 5: Maintenence
Every day, remove your weights and plate and clean them with hot soapy water.
Should you see a scum build up on the surface of your kraut - fear not. Simply skim away as much as possible. This is simple an interaction between the organisms fermenting your cabbage and air.
If after the first day the water level does not rise above the cabbage - add a saltwater brine to help it out. About a half a tablespoon per two cups of water is more than enough.
After about 4 days or so, depending on temperature, you can begin to eat your kraut. Scoop some into a jar and keep in the refrigerator while the rest of the kraut continues to age. Just be sure to repack to ensure everything is below the water line.
Step 6: Enjoy
Sour Kraut is a very health food. As it hasn't been cooked, it still contains all the nutrients it started off with. Sour Kraut is actually considered a raw vegetable and is great for your digestive system. The juice is drinkable (and quite tasty).
Be the First to Share
    • STEM Contest
      STEM Contest
    • Cookies Contest
      Cookies Contest
    • Magnets Challenge
      Magnets Challenge
    28 Discussions
    TheDanzel
    TheDanzel
    10 years ago on Introduction
    I am german and I can say you: This is no Sauerkraut!!! You have to use white cabbage!
    trebuchet03
    trebuchet03
    Luckily, Germany isn't the only place where Sauerkraut is and has been made for ages ;) But, in any case... It ferments just the same, it's used just the same - it's from the same family of plant.... It's sour, it's cabbage - Sauerkraut ;)
    TheDanzel
    TheDanzel
    I agree! But it has a german name =D ;-)
    NobodyInParticular
    NobodyInParticular
    To my unrefined palate, cabbage is cabbage. But red cabbage also has the advantage of a built-in pH indicator.
    trebuchet03
    trebuchet03
    That means you should totally make two batches, of each color.... Then do a blind taste test with a palate cleanser between samples. 6 samples (3 of each type) in random order might be enough to show a pattern :) Then, of course, document in a project :D
    NobodyInParticular
    NobodyInParticular
    If only making tasty food were that simple.
    The problem with a randomized blind taste test is that what you think you are eating and what the food looks like have as much effect on the enjoyment of food as the taste, smell, texture, and temperature.
    What you suggest does sound like a good school science project, though.
    trebuchet03
    trebuchet03
    That's why you do it, literally, blind. Base the food on smell, taste and texture. Considering it's a matter of palate, and not vision - you'll have to come up with a deduction based on those three senses. If you can blindly separate the two, and label on as better (while blind), that'd be pretty awesome :) And yes, a fairly awesome science project :)
    TheDanzel
    TheDanzel
    Ok sry - I just wanted to say that the original Sauerkraut (yes it's a german name) is made out of white cabbage or has a white color!
    I did not want to break a discussion from the fence (can I say so? )
    NobodyInParticular
    NobodyInParticular
    But food is for eating. Mostly by people who can see. A blind taste test is like testing the effectiveness of a drug only in people who consume no alcohol or other medications. It might be a helpful starting point, but is not going to get you market approval.
    trebuchet03
    trebuchet03
    The reason I suggested was not for market approval.... I just think it would make an awesome project while testing your claim:
    Arguably, food is for eating - that's for sure... But like you said, what it looks like can and will change the result. Since you never claimed to not like one or the other (just that you can't tell the difference), how it looks isn't making one think one is "icky" - just that it's the same :) And sameness is what we're trying to test :)
    charliemor3
    charliemor3
    11 years ago on Introduction
    You can use/make a device beer makers use called a water lock; or, something to that effect. It's kind of like the p-trap connected to sinks, tubs and other plumbing related items; which is used in those instances to prevent sewer gases from entering your living space. However, a smaller device would serve the same purpose too allow the co2 to escape as it builds up a little pressure. Also, it will prevent cross contamination of unwanted biodiversity within your kraut. Good fortune to you! P.S. If you like to experiment with food, try adding the whey from live culture yogurt, etc. It will give you far more in the way of healthy bacteria which will aid your digestion. In other words, the food you eat will do more for you when you eat healthy.
    brabantia
    brabantia
    I found an old crock but now I'm worried the glazing might be Led - based. Does anybody know how one can tell if old crockery is food-safe?
    abnor
    abnor
    wait.. either i read it wrong, or you started to mention water being in the bucket with no warning. like, i read it all, but all i read was you adding salt and cabbage to a buck, no name of water or your other ingredients. or is your cabbage liquidizing?! O.O
    trebuchet03
    trebuchet03
    Reply 11 years ago on Introduction
    Cabbage has a lot of water in it - the salt draws it out ;)
    From step 5,
    Water is really a misnomer - it's technically a brine - but we don't need to be English scholars every day (except for spelling and grammar, of course) :)
    abnor
    abnor
    ooooh. thank you for your wisdom :D i'm challenged when it comes to foods, or kitchens, or both
    TheStrangeAngel
    I live in the tropics, so the 'put it somewhere cool' part could be a problem.... would the dairy section of the fridge work?
    spocky83
    spocky83
    Sounds interesting... but my Bavarian half kinda has some objections (US-German/Bavarian halfbreed living in Germany for 25 years - guess that qualifies). Basically, the best thing to use would be a stoneware fermenter (anything that seals the Sauerkraut off from the air and allows the CO2 to get out without busting the whole thing... maybe your local hardware store can help you), but I'd suppose they're a little hard to get a hold of and probably not really cheap... just keeps your Sauerkraut from going bad while fermenting and you can store it for months in a cool place. Here comes the recipe: Use white cabbage (just more authentic) ... as much as you want. Cut it up into small bits (coarse cheese grater does the trick, some food processors may as well). Add a tablespoon of salt, mixed with some caraway (depends on how much you like that stuff) and 5-10 (again... de gustibus non est disputandum) juniper berries to every layer of cabbage in your fermenter. Work and pound the cabbage/salt/spices mixture as hard as you can (using your feet isn't the worst idea at all!). It will get nice and mushy as the salt drains the water from the cabbage. Add a couple of small slices of sour apple. Repeat until you're out of cabbage. Cover up your to be Sauerkraut with a couple of leafs of cabbage, put something heavy on it (bricks, bottles, etc), put a lid on it and let it sit at room temperature for two or three days until the fermenting process gets started, then move to a cooler place (cellar) and let it sit for a couple of weeks. eat it raw, cooked (the longer you cook it, the better it gets) or however you desire. note: Sauerkraut is SOUR... it is not at all sweet or anything, it has a very intense flavor and it will give you gas.
