[eng] YAW (Yet Another Wallet) Made From Recycled Stuff!!!-- [esp] Cartera Hecha Con Material Reciclado
23,213
44
14
Introduction: [eng] YAW (Yet Another Wallet) Made From Recycled Stuff!!!-- [esp] Cartera Hecha Con Material Reciclado
[eng] Another kind of wallet made from a re-used tetra brick pack! It is very durable and cheap, multiple styles and colours... so you can have one to suit all your clothes ;-)
[esp] ¡Otro tipo de cartera hecha de un tetra brick! Aguanta mucho desgaste y es barata, varios estilos y colores por lo que la puedes combinar con todo ;-)
Teacher Notes
Step 1: [eng] Necessary Materials [esp] Materiales Necesarios
[eng] This wallet is very simple to make and you need very little resources and mainly recycled ones!
You need...
1) A tetra brick pack: Any type will do, I prefer the long ones. Choose by colour, content or size...Enjoy drinking the content (if it was not empty already! ;-D), clean it and dry it...
2) Cutter knife, scissors or similar...
3) A couple of pieces of velcro or similar... Length a little less than two times the wide of the brick. Better velcro with glue, if not just use some suitable for fabric.
Note: You can get tetra bricks in the tetra brick disposal container (here in Finland its very normal to find as waste management is up-to-date standards!). Normally tetra bricks are an ecological nightmare because they tend to be done by overlaying pressed paper, a thin aluminium (aluminum US.eng X-D )foil, a plastic cover... but this ones are made only of pressed paper and a thin waxy coat!
Narices! no me acepta las tildes ni las enyes...
[esp] Esta cartera es muy facil de hacer, solo necesitas unos pocos materiales, que son los siguientes...
1) Un tetra brick: Cualquier tipo vale, yo prefiero los largos. Eli­gelo por el color, disenyo, contenido... Disfruta de su contenido, si no te lo bebiste antes... lavalo y secalo.
2) Una cuchilla (cutter), tijeras o similar...
3) Un par de trozos de velcro, de largo algo menos que el doble del ancho del tetra brick. El velcro mejor es el que tiene pegue, sino, tendras que usar un pegamento que valga para papel y telas.
Nota: En Finlandia se pueden conseguir brick en los contenedores de reciclado. Aqui es muy comun ya que el tema de reciclado lo tienen feten... Normalmente se puede considerar al tetra brick una pesadilla ecologica...Hecho de papel prensado, papel de aluminio y cubierto de plastico es muy dificil de reciclar, sin embargo, esto son unicamente de papel con una ligera capa de encerado.
Step 2: [eng] Lets Start... [esp] Comencemos...
[eng] First you need to cut the base of the brick. If you cant make an straight cut you can always fix it later.
[esp] Corta la base del brick. Si no consigues cortarlo recto, siempre puedes arreglarlo mas tarde.
Step 3: [eng] Now the Top [esp] Ahora La Parte De Arriba
[eng] From the four sides that make the top part, cut three (two sides and one front) see photo
[esp] De los cuatro lados que porman la parte de arriba, corta tres (los dos laterales y un frontal) ver foto
Note: This is only valid for tetra packs, for n-sized packs cut (n-1) sides ;-D
Nota: Solo valido para tetra packs, para packs con n-lados, cortar (n-1) ;-D
Step 4: [eng] Double Fold [esp] Doble Doblado
[eng] Now fold the sides inwards as shown and press so it stays flat. Then fold the body in half towards the top aperture, leaving out of the fold the flap. see photos
[esp] Ahora dobla los lados hacia adentro y presiona hasta que quede plano. Luego dobla el cuerpo a la mitad hacia la apertura de arriba, dejando la solapa fuera de la doblez. ver fotos
Step 5: [eng] Stick the Velcro [esp] Pega El Velcro
[eng] I used auto-stickable velcro but if you do not have, well, glue gun magic!
stick it in order to create a fix in between the two sides of the wallet and in between the flap and the outer side.see photo
[esp] Yo use velcro con pegue pero si no tienes lo puedes pegar con cualquier pegamento. Pega los velcro de manera que cierren entre las dos partes de la cartera y entre la solapa y el exterior. ver foto
Step 6: [eng] There Is Your Wallet [eng] Tu Nueva Cartera
[eng] The next step is a collection of nice bricks I have found in Finland. The cow is called Mimmi, I think... ;-)
[esp] El siguiente paso son unas fotos de algunos interesantes bricks de Finlandia. Creo que la vaca se llama Mimmi ;-)
Step 7: [eng] Tetra Collection [esp] Tetra Coleccion
umm...
Be the First to Share
    • Finish It Already Speed Challenge
    • First Time Author Contest
    • Leather Challenge
      Leather Challenge
    14 Discussions
    FOJ
    FOJ
    2 years ago
    Great idea
    nice idea dude but you could put some duct tape on packet to make them look mor nice anyways a nice and creative idea
    TonyRomero
    TonyRomero
    13 years ago on Introduction
    Well! some news! I just received this email!... Dear TonyRomero,
    Congratulations, you’ve won second prize in the DIY Wallet Challenge!
    Hihihihihi I am sooooooooo happy! :-D Thanks to all of you!!!!
    stranoster
    stranoster
    Reply 13 years ago on Introduction
    Loved your wallet but I'd actually seen these wallets for sale in Sydney. :( Good job though
    climber_geek
    climber_geek
    Very interesting & creative. But would anyone actually use a wallet made of recycled material? A wallet is just one of those things I'd prefer to buy. They are cheap, last a long time and don't do too much ecological damage in manufacturing. Manufaturing a small box of zip-lock bags is probably much worse for the environment, and will not last as long as a wallet. I've owned my wallet for 5 or 6 years. So in the long-run, the $20 I spent on it was negligible. And I find it more aethetically pleasing than a milk carton. I thought "milk" in spanish is "leche"...why do the milk boxes say "maito"?
    TonyRomero
    TonyRomero
    I am living in Finland right now so that is why it says "maito"...milk in Finn... I do agree that a wallet does last long, but the wallet I have does not have a place for coins so I use this one as a coin holder...and about the aesthetics...well I like the orange drawings. I have already made like 10 wallets for friends and family, I guess it is just for the "cool" factor... Thanks for the comment!
    climber_geek
    climber_geek
    Yeah, I guess they are cool in a campy sort of way. The 12-year old in me would like to have one but the 30-year old in me says "no". But I have to admit that those finnish milk cartons look cool with the bovine cartoons. The ones in america are usually more plain and boring.
    ferroucious
    ferroucious
    Las vacas son monas. I think that is how you say it.
    twisted
    twisted
    cool idea! dosent look like it would hold cash though
    good, clear instructions :)
    anyways, check out my wallet instructable: here
    ~Twisted
    nagutron
    nagutron
    Hey, that's cool. Like the paper wallet, but waterproof! I like how you keep a lot of the structure of the original box.
    TonyRomero
    TonyRomero
    I think its cool too and here the tetra bricks have lots of colours and "nice" arts... Actually more than waterproof it is very durable! the pressed paper lasts longer than it seems...even when the drawing has worn off the brick is basically intact... and when it is too worn out you always have a new tetra brick to use as replacement... Thanks for the comment!
    hethlee
    hethlee
    Very cool. This is a swee project. how does the velcro hold up?
