多特蒙德滑板
Introduction: 多特蒙德滑板
Dortmund Skateboard
Teacher Notes
Step 1: Make the Base Plate
Select the Cube and Adjust It to Be 80 by 20 and 4 by 4
Step 2: Select the Dome and Adjust the Thickness to 4
Step 3: Rotate 90
Rotate 90
Step 4: Copy and Paste, and Rotate 90° Horizontally. Align the Bottom Plate With the Two Semicircle Plates
Step 5: Make Wheels
Select Wheels to Adjust to 10 in Diameter and 4 in Thickness
Step 6: Rotate 90
Rotate 90
Step 7: Let Me Copy and Paste Three Identical Wheels
Step 8: Select a Cylinder and Adjust It to Diameter 2 and Height 20
Step 9: Rotate 90
Rotate 90
Step 10: The Wheels Are Aligned With the Cylinder
Step 11: Select a Cylinder and Adjust It to Diameter 3 and Length 8
Step 12: 45 ° Rotation
45 ° Rotation
Step 13: Pull the Cylinder to Align With the Wheel Group
Step 14: Copy and Paste the Set of Wheels and Rotate 180° Horizontally
Step 15: Combine the Bottom Plate and the Wheels
Align the Wheels With the Bottom Plate
Step 16: Adjust Backplate Color
Step 17: Make Text Letters and Pull Them Onto the Base Plate
Step 18: Rotate the Two Semi-cylinders Upwards by 17°
Rotate the two semi-cylinders upwards by 17°
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
