宇宙无敌超级简单滑板(Super Simple Skateboard)
Introduction: 宇宙无敌超级简单滑板(Super Simple Skateboard)
我的创意(My
creativity):
我设计的滑板,本着简洁、大方的风格进行设计。作品使用材料较少,易于加工滑板的各个组件,省时节力。
My skateboard is designed in a simple and generous style. The work uses less materials, easy to process the various components of the skateboard, saving time and effort.
Teacher Notes
Step 1: Step1:构思组合方式(Idea Combination Mode)
Step1:构思组合方式
先在图纸上,构思各个部件的大小、组合的方式,然后在工作区上建立坐标轴,以坐标轴为参考,排版各个零件的位置。
First, on the drawing, conceive the size and combination of each component, and then set up the coordinate axis in the work area, with the coordinate axis as the reference, layout the position of each part. Combine the skateboards.
Step 2: Step2:组合图形(Composite Graphics)
构建基本形状,在标尺的帮助下,使用方块、圆柱体进行组合。
Build the basic shape, with the help of ruler, use block and cylinder to combine.
Step 3: Step3:导出文件(export File)
组合各个图形,导出文件。
Combine drawings and export files.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
