滑板
It's a combination of a balance car and a skateboard, combing the characteristics of these two tools, so a skateboard was born.
Teacher Notes
Step 1: Build a Board First
Build a panel
Step 2: Chamfer
Create a new entity merge, and then make a chamfer
Step 3: Using the Method Described Above
Merge and chamfer both sides from the outside and inside at the same time.
Step 4: Shear
To cut a cuboid at the center of the plate.
Step 5: Do the Cylinderical
Close the panel and create a new cylinder.
Step 6: Punching
Open the plate surface and test whether the cylinder is suitable in size. Then close the plate surface of the plate, center on the hole, cut a circle on each side, and build another circle around the hole to make a hole on the side.
Step 7: Do the Tires
Close the plate surface, hole as the center, both sides cut a circle, hole as the center to build a circle.
Step 8: Segmentation
Turn off the built plate wheel, another round cylinder built in the previous step, then pull out the gram, and then perfrom the partition entity.
Step 9: Cut Off the Excess
Turn off the split bottom half to avoid grinding the wheels as they slide.
Step 10: Connect the Overall
Create a new cylinder with the hole center as the origin and open all the plate and wheel can be connected.
Step 11: Adjust the Scale
Adjust the legth and proportion of the plate to make it look more comfortable.
Step 12: Chartlet
The adjustment completes, look sfor a piece of oneself like picture to stick up, the completion.
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
