0G Planter
Introduction: 0G Planter
Hello my name is Wyatt I am a freshman at South Range High School.
This is a zero gravity planter. It rotates to make gravity. I created this in TinkerCad at 1/5th scale.
Supplies:
1) 3D Printer
2) Mirrors
3) Wheel bearings
4) Dirt
5) seeds
6) motor and gears.
Teacher Notes
Step 1: Planting Seeds
The soil goes in between the dividers. The seeds will be placed in the soil and will grow towards the center of the disc.
Step 2: Why Spin the Seeds
Spinning the planter will cause a gravity like effect. Since seeds want to grow against gravity. The spinning will create a gravity like force. The seed will spout and grow to the center of the disc. Then turn to grow up to the light at the top of the box. mirrors on sides will reflex light to the plants.
The planter sits on a bearing like a roller skate wheel. The motor spins it at enough speed to put force on the seed equal to earth's gravity.
Step 3: Watering
The water will travel through center of bearing into pipes to each compartment. If water was sprayed with 0 gravity it would float around and not all plants would be watered and it would block light.
Water tanks can be stored in the empty corners under the mirrors.
Step 4: The Whole Design
The motor spins the seeds. The mirrors (in green) reflect the light. The seed grow to the center then up towards the light at the top (yellow). the mirrors reflect the light under the main leaves making the plants produce more food.
Here is a link to my TinkerCad project: https://www.tinkercad.com/things/1xAtRxaUw7j-stunn...
Please vote for this project.
Growing Beyond Earth Maker Contest
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Fix It Contest
      Fix It Contest
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    22 days ago
    Thanks for sharing your design! Nice job using Tinkercad :)
