10 Watt Endurance Laser Module Power Improvement
1,107
Introduction: 10 Watt Endurance Laser Module Power Improvement
I bought 10 watt laser kit. I assembled the laser kit and connected according to the instruction When I was adjusting the laser volt and current to have good laser power and keep the laser diode safe as well I was not able to get more than 3.7A@5V
I have done some practice to improve the laser power without exceed 5V I found that the wire which connected between the laser diode and DC-DC converter should be thicker either the length should be less as possible to reduce the wire resistance to increase current. From my side I preferred to reduce the wire length.
Step 1: Soldering Protection Zener Diode Into PCB
use shrink insulation to avoid short circuit and solder the zener diode according to the picture
Step 2: Fix DC-DC Converter on Laser Body
I found that the best way is to connect the laser diode direct to to DC-Dc converter without any connection as below picture. Since I don’t have Endurance laser box so I got idea to fix the DC-Dc converter on laser frame as below
by using male/female PCB Board Standoff 3Mx6mm, 4 Pcs. fix DC-DC converter on laser body by making 4 threaded holes and install according to DC-DC converter fixing holes dim.
Step 3: DC-DC Converter and Laser Module Fans Connection
Connect the DC-DC converter fan in parallel with laser fan.
Step 4: Laser Connection
Connect the laser diode wire direct to DC-DC converter output.
connect 12VDC power supply to DC-DC converter input
Step 5: Laser Diode Volt and Current Setting
don't set the volt more than 5VDC to avoid laser damage. that is why we ad zener diode to keep laser in safe if the volt cross 5.2
the currecnt csn go more than 6A but I recommend to set the volt about 4.7VDC and current 5A or 4.5A because extra current means extra heat generation
Step 6: Loss Lens and Dust Projection Solution
in case your laser lens loss and want to be fix you can use thread Teflon to make the lens a little bit tight to avoid any vibration during work and also will protect your laser diode and and you lens from dust accumulation.
First Time Author
First Time Author
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    2 Discussions
    audreyobscura
    audreyobscura
    1 year ago
    Congrats on publishing your first Instructable. Out of curiosity, what do you use this laser for?
    AhmedI42
    AhmedI42
    Reply 23 days ago
    sorry for too late reply
    thanks a lot
    it used for CNC cutting or engraving
