10x10 RGBW LED Matrix
600
5
4
Introduction: 10x10 RGBW LED Matrix
In this project I create a 10x10 RGB LED Matrix. This project took around 8 hours of soldering. I would and wouldn't recommend this project. It takes a very long time to make but the finished product is very mesmerizing.
Teacher Notes
Step 1: Gather Materials
Here is the full list of materials:
- 100 WS2812B LEDs: http://a.co/1Y3qkxf
- 5V 4A power supply: http://a.co/6yGhpOc
- Arduino: http://a.co/6my3B0R
- Foam Board
- Translucent Acrylic
- Wood board
- Many wires
Step 2: Begin Assembling
Start tinning the solder pads of the LEDs.
Once done tinning, Drill holes for LEDs in the wooden board. The holes are around 1.7cm apart.
Step 3: Assembling and Soldering
Glue LEDs in wooden board.
Next, solder the wires on the LEDs. This will take a very long time to finish.
Step 4: Finishing the Build
Once everything is cut, start gluing the sides and foam into the panel. The foam is 18.7cm long.
Last step is the code. FastLED does not work with RGBW at the moment so you have to use Adafruits Library.
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
    4 Discussions
    CampbellB4
    CampbellB4
    7 weeks ago
    can you send the code that you used?
    thanks
    CampbellB4
    CampbellB4
    Question 2 months ago on Step 4
    is this design expandable to like a 20 x 20 LED matrix
    EvanR41
    EvanR41
    Answer 2 months ago
    For sure. The only difference would be that you would need a more powerful power supply.
    seamster
    seamster
    1 year ago
    That is indeed a lot of soldering! :)
    But the finished piece looks great. Do you have a video of it in action, and maybe the code you used? (Those would be great to include if you have them.)
