10x10x10 Speaker
Introduction: 10x10x10 Speaker
How to assemble and use the speaker designed in IDN1002.
Teacher Notes
Step 1: Circuit Board, Battery and Bottom Casing Assembly
Parts Needed:
Circuit Board
Battery
Bottom Casing
Buttons x2
Switch
First, place the battery at the end of the bottom casing, while placing the circuit board in the slot at the front. Next place the bottoms in the slots provided, and the switch on the board at the top.
Step 2: Assembling the Top Casing
Parts Needed
Speaker
Top Casing
Next, place the speaker within the hole in the top casing, and push hard. This should not move. Finally, Connect the two cases together.
Step 3: Assembling the Rest of the Speaker
Parts Needed
Feet Rings
Mesh Cover
Visualiser Rings
Now slide the feet rings on either side of the speaker. This will keep the speaker together, without fear of the components falling apart.
Push the mesh cover over the top of the feet rings. the ends should slide into the notches. Finally assemble the visualiser rings in the same fashion.
Step 4: Enjoy
The speaker is now complete. Connect to Bluetooth and enjoy.
Be the First to Share
    • Cardboard Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • 3D Printed Contest
      3D Printed Contest
