1st Mac Projector
Introduction: 1st Mac Projector
I want to make a project roller. Once people go closer, the roller will rotate and generate paper roll. The shape of the box is inspired by 1st MacBook.
acrylic board
wood stick
2 powerful servo motors
1 circuit board
Arduino uno
1 ultrasonic distance sensor
Teacher Notes
Step 1: Make the File in Illustrator(AI)
I make my each side of my box in illustrator with careful measurement. Each line of board outline need to be default blue and 0.001 pt wide since I am going to laser cut them.
Step 2: Laser Cut
I used my school machine to laser cut my file in each piece and compose them with hot glue gun.
Step 3: Make Circuit and Code
I start to make circuit. This is the tinkercard version.
the code is like this:
const int trigPin = 9;
const int echoPin = 8; // defines variables long duration; int distance;
#include
Servo myservo1; // create servo object to control a servo Servo myservo2;
void setup() { myservo1.attach(11); myservo2.attach(10);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output pinMode(echoPin, INPUT); // Sets the echoPin as an Input Serial.begin(9600);
// myservo1.write(0);
void loop() {
// Clears the trigPin digitalWrite(trigPin, LOW); delayMicroseconds(2); // Sets the trigPin on HIGH state for 10 micro seconds digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // Reads the echoPin, returns the sound wave travel time in microseconds duration = pulseIn(echoPin, HIGH); // Calculating the distance distance= duration*0.034/2; // Prints the distance on the Serial Monitor Serial.print("Distance: "); Serial.println(distance);
if(distance<20){ myservo1.write(180); myservo2.write(180); }else if(distance>20){ myservo1.write(0); myservo2.write(0); } delay(15);
Step 4: Test and Set Up the Circuit
I was testing if my code would work. It could! That's nice
Step 5: Put the Gear on the Servo
I glue the gear on the servo motors so that it can rotate the wood stick with large gear.
Step 6: Load Other Everything
Put the paper roll I printed on the wood stick. And when you get close to the machine, you the screen will move by the rotating wood stick!
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Tiny Speed Challenge
    2 Discussions
    audreyobscura
    audreyobscura
    3 months ago
    cool little mechanism!
    yoyo2333
    yoyo2333
    Reply 3 months ago
    Thank you
