3 Channel Digital LED Strip WS2812 Controller
2,861
21
Introduction: 3 Channel Digital LED Strip WS2812 Controller
About: My YouTube channel: https://www.youtube.com/channel/UCC5SU40qOutZZMCqqWBtD-g
I have always wanted an inexpensive way to control multiple digital led strips.
This instructable shows all the steps I went through in designing and building this project.
Teacher Notes
Step 1: How It Works:
It works based on microcontroller Arduino Nano ATmega328 and program Arduino, which is in C++. In program, we define each led strip, how many numbers of led diode does it have and color for each led diode individual.
Step 2: Let's Start, Parts and Tools:
Materials:
  • 1 x Arduino Nano Atmega328
  • 4 x 470Ω resistor
  • 1 x 10kΩ resistor
  • 1x fuse 2A (based on your needs)
  • 3 x LED strip type WS2812
  • 1x PCB plate
  • 5 x Input / output terminals
Total amount = 16 parts
Tools:
  • Solder gun and solder
  • Wire cutters
  • Needle nose pliers
  • Drill and drill points
  • Hand or powered saw
  • Rotary Tool
  • Sandpaper
  • Digital multimeter
  • thinner
  • rosin powder
  • brush
  • stronger plastic pot
  • Safety Glasses :)
Step 3: Designing a PCB With Computer:
To create a circuit that is fixed, you can choose between hand-drawn and
computer design. Before we start with any mode, we need to have absolutely all the components (elements) on the table, because it is necessary for the production rate of each individual element and a range of terminals (pins) element. This is good for us to make a nice visual and not overcrowded circuit, because if you would not have previously elements on the table, it could after the drawing during the manufacture of the elements too compressed or even would not be enough space to be firmly installed in the circuit.
The product will be formed with the help of a computer program EAGLE
(Easily Applicable Graphical Layout). The program allows us to draw power plan, and then using it to draw the plate elements and connections. Once you have done the layout elements and links between them we have need before printing connections on a sheet, set in the program Mirror function, otherwise the circuit seen by bird perspective. When pressed on the link list do with a ruler lightly network that we had on the computer while drawing connections is 1/10 inch (2,54mm).
This program is free and can be downloads from this link:
http://www.cadsoftusa.com/download-eagle/
I have made my own PCB board in computer program EAGLE, if you want to use my designed PCB i have posted my file for use in program EAGLE.
Step 4: Preparing the PCB :
Preparation of plates:
We are ready for the production of circuit boards, for the manufacture of the plate is used which is drilled in the form of a network that is 1/10 inch, and has on one side the copper islands. First, we cut at an appropriate size, taking care that the cut to a bigger surface area than the surface of the links. To have on at least one side type of copper islets blank. Then, purification of copper islands with iron sponge so that on smooth rubbed in one lengthwise (forwards-backwards) and without the circular movements. This work is to get clean copper from dirt from the upper surface that has been accumulated. Clarified top surface of copper needs to shine. Sharp edges rounded off.
The dimensions of the circuit:
Length: 19 in spacing of 1 / 10inch Network (4,8cm)
Width: 17 in spacing of 1 / 10inch Network (4,3cm)
Step 5: Solder Part:
Solder part
Then take a cut plate and sheet in which the connections and electrical elements and begin by soldering elements and dragging the links for copper islands.Take care that the soldering tip is always clean, because it is helping to create better connections and faster solubility of tin.
Step 6: Verification and Protective Liquid:
Verification:
Then comes a phase in which the conductivity is checked connections and possible short circuits and what possible missed connections. When we find that all connections are correct and we do not have any error going on a protective spread connection and the lower part of the circuit.
Protective liquid:
This is done on the stronger plastic pot (from an empty glue for wood cut container in the middle and give the cup) and pour thinner rosin powder and stir with a brush so long that the dust in fully decomposition, we obtain the fluid is yellow. If you pour the liquid into a softer plastic cup, after 1 min will eats it from the bottom, since it practically eats things because it is corrosive. When we have a brush greased underside of the circuit, leave the coating is dried, so we links give protection against oxidation. The coating is not relevant when soldering, so you can still fix anything.
Step 7: Specifications Circuit and Connection:
Specifications circuit (U, I, P):
  • U = 5VDC
  • I = (Based on fuse and program) A
Step 8: Programing Microcontroller:
You can download the Arduino IDE for free from:
https://www.arduino.cc/en/main/software
Step 9: Video of Working:
I hope that you enjoyed following me along with this Instructable!
Thank you for reading!
Check out the video :) :
https://www.youtube.com/watch?v=dnvf6tiV3Es
Make it Glow Contest
This is an entry in the
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
