Introduction: 3.5" Floppy PCB Christmas Star
Hello, this is my first tutorial about PCB recycling.
I am from the Bulgarian Scout Organisation and we make a christmas bazaar.Then i came with this idea.
This is my idea how to convert your old and unusefull (maybe not working) 3.5 Floppy Disk Drive in to lovely Christmas star for the Christmas tree
I havent`n seen such star like mine on the internet, so i decided to make an instructable how to make it.
Tool you will need:
1. Dremel tool,hacksaw or jigsaw to cut the PCB.
2. Screwdriver
3. Sandpaper
4. Hot Glue gun, or some glue that will stick with PCB and metal.
5. Drill with stand
6. And of course some free time :) (it took me about 50 minutes, because the PCB is getting hot too fast)
So let`s get started.
P.S. PCB-Printed Circuit Boards :)
Step 1:
Now you take your old flopy and remove all the screws you found to open it.
Then you disconnect all the cables you see on the PCB
Next remove all the screws that hold the motor and the PCB.
Now you have motor board, PCB and the aluminum chassis
For this project you will use only the motor board.
The other board and the motor for the head I will save for other projects, and the aluminum chassis i will return at metal recycle station :D
Step 2:
At this step you must Disconnect the magnet from the motor. Some of them are not connected directly(you just pull up the magnet), some are with one screw or stopping caps.
Then you can desolder the coil with your solder iron, or just cut the wires with knive.If it has screws, remove and save them.
Step 3:
Now grab a pencil, or marker and draw a star on one side of your PCB.Align the star so the coil to be in the center.
Now cut the star with the toll you have, and smooth the sides and edges
Now you have smooth and beautiful PCB star.
Step 4:
Take your tool and drill a hole in the star for the strap.
Now come the assembly part =)
You can use the hot glue gun, if it is without screws.
Step 5:
The star is almost complete.
I use an old floppy cable for the strap.Just take one wire from the cable, go through the hole that you drill and make a knot.
Finishing touch like remove the marks that you make for the cutting.
Your star is fully complete :D
I hope enjoy my tutorial, and make a great add on for your Christmas tree or a good present for your friends.
Please comment and if you have any questions, feel free to ask
Merry Christmas and Happy new year from Bulgaria.
