3D Printed Camera Slider
4,631
35
Introduction: 3D Printed Camera Slider
If you have a 3D printer it's a really easy project to make and a quick stable solution, this project was originally made as a motorized slider but for now this just the simple version.
what do you need to make it?
  1. 3D printer
  2. 12 mm metal rod (x2)
  3. 12 mm slider bearing (x4)
  4. M6,24mm screws (x4)
  5. M4,30 mm (x16)
  6. M3,7mm (x4)
  7. M2.5,14 mm (x4)
  8. M6 nuts (x4)
  9. M4 nuts (x16)
  10. M3 nuts(x4)
  11. M2.5 nuts(x4)
  12. camera mount
STL files available on Thingiverse
https://www.thingiverse.com/thing:4066850
Teacher Notes
Step 1: 3D Print Everything BUT Read the Instruction
you will find all the parts needed on Thingiverse and Cults3d
you must be careful about how you put your supports and make sure that your bed is leveled correctly.
Important NOTE
the plate is printed in two stages.
you have to print it until it reaches 6mm then you put the M4 nuts and then you continue the print the way the nuts will be embedded inside the plate.
Step 2: Assemble the Legs
remove the supports and use the M2.5*14mm screws and put the nuts in their holes.
Step 3: Assemble the Plate
Use the M4*30 mm screws and put the bearings in the right place
Step 4: Take a Look at Your Cat (it Helps)
Step 5: Assemble the Knobs
Use the M6*24mm screws
Step 6: Put the Nuts in There Right Places
use the M3 and M6 nuts and put them in the right places
Step 7: Slide the Metal Rods in the Plate
Step 8: Assemble the Sides
just put the legs in the holes made for them and make sure that the gears go inside the corresponding places, then put the knobs and tighten them.
Step 9: Assemble the Slider
put the 12mm rods and make sure they are completely inside the hole then use the M3*7mm to secure the rods to the sides and make sure they are tightened very well.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
